Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Problem embedding Map Monkey
  1. #11
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Partybuster
    I must be doing something wrong once again because when MM is loaded within RR the tskbar at the bottom appears above MM and covers 80% of the MM-buttons. I tried different window names but no success. Any help is apreciated.
    Panel control \ Set to " automatically hide the bar of the applications".
    Test it.
    Mauri
  2. #12
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    Thanks Mauri, that worked.
    Is that the only way to hide the taskbar?
  3. #13
    FLAC mauri's Avatar
    Jan 2004
    Yes , its one old bug of MC not solved by Coyote.....
    Mauri
  4. #14
    Amsterdam
    OK, did not know that, thanks again.
    Pherhaps Guino can do something about it when he has finished other more important things.
  5. #15
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I could add something to hide the taskbar alltogether, but you might run into trouble doing that... I'd just suggest to not use that "keep task bar on top" option -- leave it OFF, and it shoudn't bother ...
  6. #16
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Problem with task bar
    If you set the "Hide task bar option in windows, then the taskbar hides and all the button are shown. If you press the lower button of MM or Freedrive then the taskbar is shown again. Am I doing something wrong or is it like this ?
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tolisn
    ummm.. you don't want to do that option.. you want to leave that OFF and also turn off the option that says "Keep taskbar on top"...
    Ride Runner RR's Myspace
  8. #18
    Dec 2003
    Greece
    Guino you ARE the man.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 09:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
