Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 89
Thread: Road Runner Installation Program
  1. #41
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by ccsnet
    easier for newbies to edit etc.
    n00bz!
    No prob. INIs are fine, just a bit reminiscent of the WFW era
  2. #42
    Aug 2004
    The install program for international users is wrong. Remember that "Program Files" is called different names depending on which language version of Windows you are using. In Norway, the directory "Program Files" is called "Programfiler". The install program install correctly into "Programfiler", but when you run the program, it's looking for the skin file in "Program Files". Then you manually have to copy the skin file to this new directory. You also have to change all files in the Config-program to point to "Programfiler" in stead of "Program Files". Please correct.
  3. #43
    Deactivated Diewlay Lowmo's Avatar
    Aug 2004
    Does anyone have an older version?
    I accidentally deleted it off my HD.
    The new one doesn't install properly.
  4. #44
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ummm.. what kind of problem you're getting with the install ? It'd be a good idea to post it so we can try and fix it... Installing RR manually is not that difficult.. in fact I think it's time I work on a FAQ for this...
    Ride Runner RR's Myspace
  5. #45
    Aug 2004
    This program http://www.majesticpw.com/roadrunner...ner3-20-05.exe freezes at 99% during the install, and I cant delete it off my system. How can I delete it off my system now?
  6. #46
    Nov 2004
    I just tried it and it works perfect on my systems that I have tested on. Please redownload the File and run it off of your computer. See if that fixes it.
    Other than that, you should beable to go to the Add/Remove Programs and select Remove.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  7. #47
    Aug 2004
    You got PM
  8. #48
    Nov 2004
    Netherlands
    Quote Originally Posted by Diewlay Lowmo
    Same here, it hangs at copying tvskin or something like that.
    I just used an older version and updated it with the binaries from the roadrunner website.
  9. #49
    Aug 2004
    Exactly but unfortunately I no longer have an older version..
    *Edit* I downloaded the binary version, and manually set it up, thanks.
  10. #50
    Dec 2004
    Manhattan, NY
    The requested URL /roadrunner/road-runner3-20-05.exe was not found on this server.
    Link seems to be dead
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
  3. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
  4. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 03:48 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
