Page 1 of 9 123456789 LastLast
Results 1 to 10 of 89
Thread: Road Runner Installation Program
    Nov 2004
    Updated File at 10:45AM EST 2-8-05
    Click Here to download my RoadRunner 8/21/2005 Install.
    GUINO> Last known working link:
    http://www.majesticpw.com/roadrunner...ner8-21-05.exe
    NOTE: This install will only work for XP or 2000. This doesn't support Windows 98 or ME.
    This will do the following and make the following Directories:
    1) It Installs the Brushed Metal Skin from Guino's website, with the Updates.
    2) It Copies the Road Runner Files as of 2/8/2005 release to the following Directory: C:\Program Files\Road Runner\.
    3) It copies the mediaplayerc.exe file to the C:\Program Files\Road Runner\ directory.
    4) It copies the Gamma files to a C:\Program Files\Road Runner\Gamma Directory.
    5) It creates a Desktop Icon, and also a Pograms Group for Road Runner, off of the Start Menu.
    6) At the end of the Installation, it opens the Config Program so that you can make any changes that you might need. It will also show you the Readme.txt file.
    7) Installs the Fonts for the above Skin to the correct Directory under Windows 2000 or XP.
    If anyone has any suggestions, that will make it easier, let me know and I will try to change what is needed.
    Also, if you install this and get any future Installs, you can just use the Update Command. You will see this if you install the Program, and then try to install it again, it will state Update and Remove as options.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    I'm downloading right now, so I don't know how it works yet, but I think this is a very welcome tool for many of us. And it should have been made long before!! Also for other FE's!
    Nov 2004
    Let me know, I have made it as easy as Possible. I can do pretty much whatever we need in this, I could also find away to make it install the Mediacar, if needed, so let me know what everyone thinks.
    I know that I had problems, right at first when I was trying to get Road Runner set up, my problem was that I forgot to add the fonts. So, we all make mistakes, and this should greatly help, since there are so many little pieces that you need to do to make it all work correctly.
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
    Raw Wave
    Jun 2004
    On the beach
    Hey bry21317,
    A few problems I found ---- gama folder incorrect - needs renaming to gamma.
    Skins folder doesn't appear in the ini file upon installation. No other problems as yet - manually altered to work.
    Nov 2004
    When you say, the Skins Folder doesn't appear in the .ini file after Installation, are you sure this is correct? I am not having any problems with this.
    I did find the Gamma folder was incorrect, and am fixing this right now.
    I will be checking and updating this link on my site pretty soon.
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
    Raw Wave
    Jun 2004
    On the beach
    Well ..... as the brushmetalhonda is installed as default surely it should point to here???
    Maybe I'm wrong
    Newbie maxzor's Avatar
    Feb 2005
    Italy
    Problems with WinAmp and RR
    Hi, I'm new and I had download Road runner.
    I can't see the video in RR window but I must clik on winamp and it isn't embed.
    my winamp is 5.08 pro
    Can anyone help me please?
    Dec 2004
    Netherlands
    Didn't work for me...
    I get a - run time error '76' - path not found - error.
    I checked my config setting, and can't find any false path's...
    Also few suggestions
    Add an option to choose a quick launch icon besides the shortcut.
    Include winamp install if possible, or is that a copyrighted programm?
    maybe a option to choose what to install or not, if it's already on your pc.
    Raw Wave
    Jun 2004
    On the beach
    Phythorian, rename c:\program files\road runner\gama to c:\program files\road runner\gamma
    and also make sure that there is a path in the rr.ini after the skins=
    Dec 2004
    Netherlands
    Yep, That did the trick!!
    Now it works for me!
    I had RR installed allready, but I think these kind of prog's makes live a lot better!!
    Thx !
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
  3. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
  4. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 03:48 PM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
