Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Road Runner 02-04-05
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by organasised
    I tagged this on to the auto resume thread but incase you don` see it
    Any chance of an extra button on the video panel? Id like to be able to switch between 2 or more playlists withought having to go into another screen
    ie switch between my 2 directories: one with my movies in and 2nd with music videos in
    maybe similar playlists in music too
    Well.. that kind of sounds redundant.. why not make a structure like:
    D:\Videos\ and two subfolders inside it: Movies and Music Videos ?
    anyway, get some more to request the same and I can add it.. you'll probably have to find someone to make a skin change first...
  2. #12
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    Quote Originally Posted by guino
    I have no idea what is this winamp problem you have, care to give an insight as to when or what you do to get it..
    I have to test girder with the video player more throughly, specially while it is on it's trial time..
    I'll check on the click to open file.. I've been meaning to do that for awhile, but keep forgetting...
    I have not added any "keyboard" support yet, will do that soon.. but have taken note of your idea for going in and out of folders..
    Not sure I understand your suggestion about the icons.. right now the folder list shows icons for Folders and for Files -- they can be customized with the skin used by placing a folder.ico|gif and media.ico|gif in the skin folder. If you by any chance don't see any icons, then just click on the "Show Icons" option in the config tool..
    The Gamma thing, I intended and had made it close before, but took it out for reasons of interfacing.. it's easy to make the Gamma application close, but Gamma panel's icon stays "dead" in the taskbar and GammaControl might be used by some with NaviVoice... so maybe I'll have to make an option for that..
    The Winamp bug seems to be random as i am unable to make it happen in the new version.
    I just realised the Show Icons settings it looks great thanks.
  3. #13
    Oct 2004
    Atlanta, GA
    Just looked at the new version ... clear playlist is clearing Winamp, but not the RR playlist screen.
    Lexus SC300:
    Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/M4-ATX PSU/Rikaline 6010 GPS/RR/iGuidance 4
    Corvette:
    VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX PSU/Xenarc 7" TS/BU-353 GPS/RR/iGuidance 4
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by rhubarb9999
    True, sorry my bad.. have fixed it for next update.. as long as you add a folder/song with Select/Sekect+/Add1 then it should reload the list correctly.
  5. #15
    Oct 2004
    Atlanta, GA
    I see your point on the lazy loading of the MP3 tag info. The only place that I use track numbers is for albums .. the folders I have with 1000 songs are all compilations .. and I have removed all the track numbers .. but I guess it would still have to 'look' at all the files .. because it does not know that.
    Well .. if others want it .. and you can add it as an option .. that would be cool. If not, I can use the tag info to rename the albums I have that dont have the track number in the filename. No biggie.
    Lexus SC300:
    Corvette:
  6. #16
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    what IR remote do you guys recommend? (one that works with girder)
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 10:22 PM
  2. Road Runner -- New Version 2-2-2005 :)
    By guino in forum Road Runner
    Last Post: 02-08-2005, 10:01 PM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
  4. Yeah! Road Runner -- REMedia Car no more..
    Last Post: 01-31-2005, 05:03 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 01:30 AM
