Page 14 of 17 FirstFirst ... 4567891011121314151617 LastLast
Results 131 to 140 of 164
Thread: Update: 2-12-05.. Flash Support!...
  1. #131
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Chita79
    what are the main things u wanna add for the next release guino? (perhaps minimize button??? huh huh huh..) :P
    Why do you want to minimize Road Runner?
    It's the cake having/eating thing.
  2. #132
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'd love to have RR be in the task bar. I find it very annoying having to minimize all my apps manually to get to RR.
  3. #133
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 0l33l
    I can add that easily.. I think... :/ hehehe the thing here is that the screens that make p the skins are dynamicly loaded so I can not show them on the taskbar or you might end up with a ton of RR's on the taskbar.. so I gotta use another window and handle when you try to restore/switch to it..
  4. #134
    Jan 2003
    Ruston, LA
    Quote Originally Posted by guino
    Just make them all visible on the taskbar. As long as the other windows are
    hidden at the time, only one will be visible on the taskbar at a time.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #135
    Jul 2004
    Berkeley, CA
    Cool. Also, how about a minimize and restore function. Try out NaviVoice and tell me what you think
  6. #136
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by frodobaggins
    Yeah, the problem is when I show Menus (over other screens) they're the same exact form (so you could have menus with anything) and there's no way to turn it off at runtime... anyway, I'll get something worked out.. I believe I have done that in the past ..
  7. #137
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Guino,
    I went thru the code and I trick a little to have Map monkey embeded. The reason I found that it didn't embeded with the binary I down loaded is you hard code "Map Monkey -" when searching for window name.
    This is what I change in modRoadRunner\Exec
    Code:
               'Load/Show Map Monkey
                If FindWindowByPartialTitle(GPS_NAME) = 0 Then
                    'Load Map Monkey and fix it in place
                    DoLog "Shell: " + Chr(34) + MapMonkey_PATH + Chr(34)
                    Shell Chr(34) + MapMonkey_PATH + Chr(34), vbNormalFocus
                Else
                    'Show Window
                    HideWindow GPS_NAME, False
                End If
                Menus(t).ShowForm
                Frm.Hide
                FormBottom Menus(t).hwnd, GPS_NAME
                Menus(t).AppName = GPS_NAME
                Menus(t).Caller = Frm.Tag
                CurSCR = "destinator_gps.skin"
    It will embeded Map Monkey or D3 beta fine.
    One problem is that MM/D3 doesn't fit within RR skin/window.
    If I have RR run at top = 50 and left = 50, MM/D3 will embed at 0, 0 instead of 50, 50.
    Maybe you can make a chang to the code.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #138
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by MatrixPC
    Guino,
    They told me to use "Map Monkey -" for the window name.. I guess you're using D3 (Old version) instead of Map Monkey (New version). The GPS_NAME is used for the external GPS, that's why I hard code Map Monkey.. if that's the only GPS you use, you could have set to use External GPS and set the path/name for it.. just didn't expect anybody to be using the old D3 when Map Monkey release (non-beta) is out and it is FREE as always ..
  9. #139
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    any more thoughs on tring to get rid of those playlist numbers...pls
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #140
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    yeah... im really interested in getting rid of those numbers.... waddya think guino?
    Also, are you planning to add a minimize feature available in the near future?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
