Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 164
Thread: Update: 2-12-05.. Flash Support!...
  1. #21
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by guino
    For this, copy your External_GPS files to like EXternal_APP_xxx.jpg and the same for the External_gps.skin to external_app.skin, then use the LOAD command to load and run your app enbbeded:
    "LOAD;EXTERNAL_APP.SKIN;ENBEDDED NOTEPAD;C:\windows\notepad.exe;NOTEPAD"
    You can edit the AXX,XXX... line to define the area in which the application should be placed in the screen.
    This stuff is all documented in the skin commands.txt file.
    Thats a good way of doing it - thanks...
    BTW - I'd class this more as technque than a function... what you have in the readme is really detailed function wise but probably not that obvious to those that don't know how the prog works when used together.
    Well done and thanks
    Terran
    ( Probably worth adding to your next realease readme )
  2. #22
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    Thanks for the quick update clear playlist seems to work now and so does girder in fullscreen video but there is now a new bug for me in video mode.
    When i first launch Road Runner and go to Video Mode I have to open a file 2 or 3 times for it to finally play once a video is succesfully played then all other files open on the 1st go. This bug happens everytime for me so i don't think it's random and i've only encounterd it on this version.
    Thanks for your hard work.
    Naz
  3. #23
    Nov 2004
    Guino,
    Here is the New Debug.txt file for my Error: 53
    2/6/2005 10:08:28 PM: Start
    2/6/2005 10:08:28 PM: Master Vol: Volume Control/4
    2/6/2005 10:08:28 PM: GetLineControl Failed: 401
    2/6/2005 10:08:28 PM: No Treble Support
    2/6/2005 10:08:28 PM: No Bass Support
    2/6/2005 10:08:28 PM: No Master ON/OFF
    2/6/2005 10:08:28 PM: Source: Wave=&H1008/1
    2/6/2005 10:08:28 PM: Source: SW Synth=&H1004/2
    2/6/2005 10:08:28 PM: Source: 3D Depth=&H100A/3
    2/6/2005 10:08:29 PM: Source: SPDIF=&H1001/4
    2/6/2005 10:08:29 PM: Source: Aux=&H100A/5
    2/6/2005 10:08:29 PM: Source: TV Tuner Audio=&H1000/6
    2/6/2005 10:08:29 PM: Source: CD Player=&H1005/7
    2/6/2005 10:08:29 PM: Source: Line In=&H1002/8
    2/6/2005 10:08:29 PM: Source: Microphone=&H1003/9
    2/6/2005 10:08:29 PM: Source: Phone Line=&H1006/10
    2/6/2005 10:08:29 PM: Source: PC Speaker=&H100A/11
    2/6/2005 10:08:29 PM: Shell: "C:\Program Files\Road Runner\Gamma\GammaControl.exe"
    Error Runtime Failure '53'
    File Not Found.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  4. #24
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by vortex
    Naz
    when you click on "video" to go into the video player, does it start playing anything at all ? What exactly do you do 2 or three times for it to work (browse, then select ??)
    I don't believe to have changed any of the video handling, but I'll double check...
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bry21317
    Guino,
    File Not Found.
    Thanks,
    Bryan
    Ok man, After all the prevention I added, I have double checked and Added one more prevention: Missing "Pointer" file for sliders. It is the only thing I could find that could possibly cause an error 53...
    You should double check your menu.skin (and other .skin) files to make sure they refer to a VALID file for the slider Pointer. From my BrushMetal updated menu.skin shows:
    S01,271,472,260,030,271,472,260,030,H,01,"SLIDER3\ POINTER.gif",013,"MASTER","Master"
    If that file POINTER.gif is NOT there, then you'll get an error 53. Please double check that that file is there and that you can open it (i.e. MSPAINT). Also make sure that it is in the indicated sub folder.
    I'll try to make another update later today, including this extra prevention.
  6. #26
    Feb 2005
    London, UK
    When i go to video it does not play anything at first I then go into FileList then browse to the file i want to open then click on Select Button which takes me back to the Video Preview mode but nothing happens just blank screen I do this two or three times then it works. Once it works once it works all the time untill i exit and re-launch.
    My Videos are all stored in folders inside the Video Folders so there is no Videos in the actual Root Video Folder.
    I have done some more testing if i put a video file in the root video folder then it is automatically played when i click on Video and there is no problem if i select another video file from the file list.
    So i guess I have to put a video file in my Root Video Folder for it to work correctly.
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you double check your videopath setting is ending on a '\' ?
    I'm taking a last look and I'll post another update shortly..
    EDIT: Made a small update for the "File Not Found" and the Video issues above... please let me know the results (when I say this is because it works fine for me.. )
  8. #28
    Jan 2005
    Is "List follows song" option not considered in versions after 02-02 any more? I really miss this one.
  9. #29
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by BadWave
    it should be.. is this not working ?? :/
    All it does is select/highlight the currently played song AFTER automatic song change.. I can double check on this..
  10. #30
    Feb 2004
    posted this in another thread but the problem still remains so..
    think i found a bug...when holding the scroll button for a loger time then releasing it, it doesen´t resume the song but jups to the next one instead, now, klicking on the rew button only makes it look like being pressed...then you have to klick again to make it jump back
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
