Page 6 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 164
Thread: Update: 2-12-05.. Flash Support!...
  1. #51
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    I have a question about the next/forward button. If I press this button once I will go to the next track in the playlist. But what should happen when I keep it pressed for some time? Shouldn't it work like a fast forward button? Whenever I do that I can see the timer count fast but when I want to stop and I release the button it always goes to the next track. So the fast forward option doesn't work at all. Is this normal and can it be fixed?
    I have a lot of albums on one single mp3 and not having a fast forward option really s4ck$ !
  2. #52
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Partybuster
    It is supposed to work... and I can say it is, but for some reason, it is also executing as if you had performed a "quick click" on it.. never seen that before, but I'll look into it..
  3. #53
    Feb 2004
    Quote Originally Posted by guino
    Even on 2-7-05 version ?? gezz.. I thought I had taken care of it..
    i had hoped so too =) donīt worry, iīm counting on you, just take it slow and take your time =)
    edit: you also still have the scroll error...when i speed through a song, and i release the ffd button, it plays the next song instead of playing the spot where i released the key
  4. #54
    FLAC mauri's Avatar
    Jan 2004
    New update is good!
    ID3 perfect....
    EDIT:i have see what if and active Map Monkey and an audio files,if close everything with EXIT button, stop audio ok,but Map Mokey is active hidden, instead i close Map Monkey with EXIT button ,all ok.
    Mauri
  5. #55
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    guino guino guino.... not bad... not bad at all ... im thinking of migrating over to your app from frodoplayer, BUT... i have some requests/fixes (unless u already have these features planned..) first, why is it that all my music/video files dont come up fully? for example, say i have "Abba - Dancing Queen.mp3", it just displays "Dancing Queen". Second, are there plans for a search function (with OSK) for songs/videos? Third, Do you think you can make some sort of progress bar for video files (so u can seach thru videos quicker)? Also, what kinda support do u have for remote controls (ati or girder) and voice commands? and Lastly, are playlists possible for videos? (i didnt see it...) if i think of anything else, ill be sure to tell ya thanks and great job!
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  6. #56
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by Chita79
    If you have it reading ID3 tags, in the default config it only displays the title where TRACKNAME is defined in your skin. You can use the config tool to make it show other things though, like %title% - %artist% - %album%, etc etc.
    According to the skin commands.txt there should be some new tags for ID3 info placement in an upcoming version of RR.
    If you don't have ID3 tags turned on, the default title delineator is the hyphen. So when it parses filenames, it finds the last hyphen and I'm guessing it assumes the rest of the filename to the extension is the title. This can also be changed (or disabled entirely) in the config tool.
  7. #57
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi fella, just tried embedded the latest version of FreeDrive, it seems to do it fine, menus are now on top, but it seems to be altering the alignment of the transparent labels on the menus, I will look into this. But I find that when I go back to the main menu and then back the the gps, sometimes its still there, othertimes it doesnt display the window again.
    Cheers and keep up the good work
    CdR
  8. #58
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    In the config program you can set what Id3 tags you want displayed eg Artist and Trackname or you can just disable ID3 tags so it should just display the filename.
    Road Runner comes with a gml file which you can import and use in girder it's just missing on the latest release 2-07-05.
  9. #59
    Oct 2004
    San Diego, CA
    ok, i fixed the id3/filename issue... i wanted to know if there a way for the playlist listing to NOT show the numbering (just the filenames) Also, what remotes will work with girder/roadrunner? will keyspan work? i searched thru this forum and i havent seen any definate answers on that... thanks again guys! oh.... is there a search utitily in RR? i noticed the skin has the jpgs, ... just wondering
  10. #60
    Oct 2004
    San Diego, CA
    this might be a stupid question but... when u hit the mute button, shouldnt it change states when its muted? when i hit mine it doesnt change ..... perhaps its a skinning issue...
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
