Page 8 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 71 to 80 of 164
Thread: Update: 2-12-05.. Flash Support!...
  1. #71
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Chita79
    very nice! what kinda functions can u simulate with the remote? there are so many buttons on there, can u assign most of them? thanks vortex!
    I'd assume it can simulate all functions..
    Sorry I forgot to include the GML file in the binary package of RR.. It is in the Source Package though (which is about 100Kb more only).
    Attached you should find the current GML file..
    Attached Files Attached Files
  2. #72
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    im thinking of migrating over to your app from frodoplayer, BUT... i have some requests/fixes (unless u already have these features planned..) first, are there plans for a search function (with OSK) for songs/videos? Second, Do you think you can make some sort of progress bar for video files (so u can seach thru videos quicker)? and Lastly, are playlists possible for videos? (i didnt see it...) if i think of anything else, ill be sure to tell ya thanks and great job! (oh.. by the way... whats the diff between the '+' button and the other one below it for playlists)
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  3. #73
    guino's Avatar
    Nov 2004
    Toronto, Canada
    -Playlists for both MP3 and Video (M3U files in general) are in my plans...
    -OSK (for anything) is in my plans..
    -Search is also in my plans..
    -Video SeekBar: this is very tricky, I have a function made for it but never had the guts to release it because its very "funky", so I have to test more.
    -The difference between + and +1 (right now) is that one adds and returns to player, the other simply adds and stays in the browser so you can keep on adding more stuff.
  4. #74
    Oct 2004
    San Diego, CA
    how about better dvd menu control like frododvd?
  5. #75
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use FrodoDVD in RR if you'd like to (as default DVD player OR as a launch application.. you also have two more options:
    -edit/change the Skin (so you can place the controls you want, anywhere) If all you want are BIG buttons, this is probably a way of doing so
    -edit the source code to make custom actions in the DVD player (for whatever that may be)
    I do believe the DVD player from MPC is fairly complete.. it could use, at most, that seekbar... other than that, has menus support, chapter jumping, aspect ratio etc...
  6. #76
    Oct 2004
    San Diego, CA
    did u update your website to the 2-8 releases? when i download it it still says 2-7
  7. #77
    Oct 2004
    San Diego, CA
    you should also consider putting play controls on the video file listing, not just the full screen view, and also perhaps being able to not have numbers b4 the filenames in the playlist section (i personally dont care what number it is)... keep up the great work!
  8. #78
    Nov 2004
    Updated Install with this new version as of 2-8-05.
    http://www.majesticpw.com/roadrunner/Index.html
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  9. #79
    Oct 2004
    San Diego, CA
    the link is down
  10. #80
    Nov 2004
    Sorry, this was a typo in the Filename. Fixed now.
    Also, Guino, should the Scroll Titles work? If not, then this would be nice to be added, so that whatever Information from the ID3 that you have selected in the .ini file, it would scroll this, such as what Winamp does with the same files.
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
