Page 9 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 81 to 90 of 164
Thread: Update: 2-12-05.. Flash Support!...
  1. #81
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    it would also be nice to see the full screen visualizations on this app.... when i hit the "eye" button, it does nothing...
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  2. #82
    Nov 2004
    Never tried this, but your correct that the Eye doesn't fire off the Visualizations, little bell and whistle, not needed for Funtionality, but would be nice in the future.
    Did you get the Install to work? How did you like it?
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  3. #83
    Oct 2004
    San Diego, CA
    about to install it now... lets see what we have... muhaha
  4. #84
    Oct 2004
    San Diego, CA
    hmmm, very weird... it seems as thought its not keeping the changes in the config when i change to an external dvd player (frododvd)... it did it in the previous release... strange...
  5. #85
    Oct 2004
    San Diego, CA
    oh btw... i see you changed the mute button, perhaps you could do the same with the main menu screen as well... wouldnt it be better to keep the button pressed so you know its muted? as oppose to a little light that we can barely see in a carpc? (just giving my advice) good work!
  6. #86
    Oct 2004
    San Diego, CA
    i know im killin this threat here, but i also wondered why my folders arent showing correctly... for example i have a folder called "Mp3 Albums (DVD)" and it shows up as "Mp3 Albums (dvd)" ... im just wondering why it doesnt capalize the "dvd"... strange .... i also noticed that the slider bar goes away when u create a playlist, until u clear the playlist and go back to the main menu and then back to playlist will the progress bar show up again, hmmmmm
  7. #87
    Oct 2004
    San Diego, CA
    suggestion..... for your video listing, why dont u use that wasted space on the left and make a preview screen, and then you can go thru your list, rather than going back from full view to see what else u have. Also, instead of going to a full view when u play, maybe you should just have a button on the left that goes back and forth between full screen view and back to the video listing... my 2 cents once again
  8. #88
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Chita79, I'm glad you seem to be enthusiastic with the application.. many of your requests are possible with the current version.. unfortunately, I don't do any graphics whatsoever (I can barely manage MSPaint), so you'd have to find somebody with image/graphics expertise to cahnge the skins the way you'd like them to be...
    The Captalization "issue", it's a simple "firstcase" function that captilizes only the first letter of every word regardless of what they start with. It is possible to turn it off, by not using ID3 Tags.. you can easily disable it in the code if it's really that annoying.
    Your "slider" issue seems like a problem with your skin files.. You can try and download the full skin or re-check your files.. it should NOT dissapear unless one of your audio_player jpegs is incorrect (without the slider).
    The visualization button is no bug.. just not yet implemented.. just trying to figure out a way to close some of those full screen visualizations that actually require a menu option or keyboard input to close... it's on my to-do list.
  9. #89
    Oct 2004
    San Diego, CA
    should i have both a "Slider 1" and "Slider 3" folders in my skin? maybe thats the issue ....
    if you can possibly get the folders and files displayed just like they are named, id appreciate that very much
    Also, if you can make an option to get rid of playlist numbering, that would be great too... especially when it says "1120 112 - dance with me" heheh
  10. #90
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Chita79
    I believe you might need them both, you'd have to check the .skin files (I haven't), but it won't hurt if you have extra files in there..
    Oh.. I guess you use that tracknumber Tag info ... I'll look into it.. should be simple to do..
    I'll look into making an option to remove the formatting.. it just kind of sucks to have to change the INI option syntax...
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
