Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 164
Thread: Update: 2-12-05.. Flash Support!...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Release 2-12-05 is out...
    http://guino.home.insightbb.com
    Update Includes the below listed (I'll use the bullet thingy):
    • Added Flash Support! (see sample with Skin Update)
    • Updated BrushMetal Skin with TV support
    • Added Mix ID3 tag load (loads available ID3 info separately)
    • Fixed "freeze" bug when software was running past mid-night
    • Yet more prevention against empty playlists
    About RADIO: Got that RadioTime card ordered.. now I gotta wait again..
    Try it at will, let me know of any bugs.. if you're having some sort of problem/bug, please add this line into the RR.INI file:
    debugmode=true
    Then try to reproduce the problem and send me the debug.txt file created in RR's folder.
    Thanks for your support,
    Enjoy!
    Next to come:
    -D-Link Radio support
    -Radiator Support
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    Girder:
    So far it's very cool remote works awsome in Audio mode but having some problems in video mode where the remote buttons dont seem to do anything when a video file is displayed full screen but when the info bar is displayed at the bottom the remote functions work fine without problems but i'd like to be able to use remote when a video is playing full screen i belive rr.exe is not receiving the remote commands when MPC is on top.
    PlayList
    ID3 is working ok now but would be cool if you could set which fields are displayed eg. Artist & Track Name or Album Name & Track Name.
    BUG: If i open a M3U file it opens the playlist and every other audio file in the subdirectories of where that m3u file is saved.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by vortex
    Girder:
    PlayList
    I'll try the Girder with video -- haven't had a chance to do it yet, but what you said makes sense, just need to add some extra code for full screen support..
    I was planning on adding the format for the playlist display.
    I haven't made any special handling for M3U files yet, if you want to simply open the M3U file by itself, then clear the playlist and use the ADD1 Button to add only the playlist.
    Feb 2005
    London, UK
    OK great i hope you sort out the girder problem.
    Clear Playlist dont seem to work properly if i clear playlist the playlist on winamp is cleared but not in road runner so if i select a song it crashes Road Runner as it doesnt exist in winamp.
    In GPS mode using Map Monkey my start bar is displaying on top of Map Monkey covering half of the buttons if i click on the top at road runners title bar then the start bar dissapears but re-appears if i click anywhere on map monkey. Not sure if this is a problem with road runner or map monkey as i also had the same problem with Media Car with Map Monkey.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    -Ok, fixed the Girder-Video issue.. it works fine now both when the controls are displayed and when they're hidden.
    -I've fixed anothe bug with clear playlist, and added some more prevention against it crashing the software...
    -This taskbar "issue" is just an option of the taskbar itself -- you should just NOT use the "keep task bar on top of other windows option".
    I'll post those changes sometime tomorrow with the next update..
    Feb 2005
    London, UK
    Quote Originally Posted by guino
    Thanks for the task bar trick it has worked!
    One thing i noticed is if i close Map Monkey from whithin Map Monkey menu then Road Runner still displays a black GPS page until i press X or Back.
    Thanks for your help and i can't wait till next version
    Nov 2004
    I get an error with the new version, 2-5-05 Binary download, since the source wasn't yet updated.
    Here is the Error that I am getting:
    Run-time error '53'
    File not found.
    This occurs on My laptp, I am just trying to test the new version before Putting it to the car. I then opened just Winamp and click Play, the same file plays not problem.
    Any Ideas? This is also with the ID3 tags on and off, both.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Well of course it does, that's what the X is for!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bry21317
    Run-time error '53'
    File not found.
    Thanks,
    Bryan
    It's somewhat unsafe to close the screen when detecting that the enbbeded application has closed -- also, this provides for better future interfacing capabilities (i.e. running and alternating applications from same screen likin in the launch screen)
    I believe you might be having problem with a playlist bug I just fixed.. can you tell me what exactly you do to get it ? Or better yet, add:
    debugmode=true
    That is, into your RR.INI file, run RR and cause the problem and PM me with the debug.txt file.
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    Does the launch applications option already work?
    I'm trying to start some apps within RR but no success so far. I love to start floats mobile control to connect with my K700 mobile. This allows me to use the mobile as a remote control for all aplications on the pc (for example controlling winamp, mediaplayer, rebooting pc, shutting down lilliput, etc.)
    If the launch option is already active I would apreciate some help in making it work.
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
