Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Radio support ?
    Low Bitrate leckan's Avatar
    Jan 2005
    Dalarna,Sweden
    Radio support!
    Is it possible to use confusedīs radio plugin software
    in roadrunner. this is already a working software and
    embedding this in roadrunner in the radiobutton
    http://www.my105e.com/carputer/Media...iaCarRadio.zip
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by leckan
    I'll definitely check it out... If you can't tell yet: I love integrating stuff that already works
    EDIT:
    Hey, this is meant so you use Radiator with the MediaCar interface right ??
    I haven't tested it yet, but sounds like a great way to cut development and test time.. I can make a direct option to run this radio plugin through the main menu skin. In fact, you can do it already by simply changing the skin code from "RADIO" to "RUNW;!C:\Program Files\Road Runner\RADIO.EXE".
    This should hide RR, launch the radio application, wait til it's done, then return to RR.
    Care to try and let me know ??
    PS: D-Link FM support will be implemented because it is very simple and I bought a card to do testing...
    FLAC mauri's Avatar
    Jan 2004
    D-Link DRU-100 support , please.......
    Mauri
    Feb 2004
    Germany
    No, not this crappy radiocard please.
    Hmm, good with radiator support I can live
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Winni
    I'm planning on both, although, Radiator does offer support to D-Link's FM card through an alternative driver.
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Quote Originally Posted by guino
    Yes, it's true... and radiator works better than the old media car radio support. Don't forget to put auto line-in opening and closing when open radio application. In any case for me it's better if volume control master instead of line in...
    P.S. clearlist command works (doesn't give error) but don't clear the list window... bye
    See my car and donate for spinning logos at www.ildena.it/carpc
    Jan 2005
    Dalarna,Sweden
    I have checking it out and i used the code u had inte the
    skin commands file and embedded the radio app and made
    a express skin to try it down here i have a screenshot.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Is this working well ?? cause hell, it might be quicker than I ever expected to do it then...
    I'd still want to make it buit-in RR's as to allow for the improved skin functions in the Radio Screen...
    Dec 2004
    Italy
    It works... but it's better what you said about an inner RR supportit... there's something that can be improved (master volume control, presets stations that can be added only through radiator's original program ecc...)
    Jan 2004
    do any of these work with channel name input though the skin
    the download on this dont support it
    any downloads ??????
  1. MediaCar Radio support
    By Maņana in forum MediaCar
    Last Post: 08-09-2004, 04:51 PM
  2. radio support
    By mutilator in forum Media Engine
    Last Post: 07-03-2004, 06:07 AM
  3. Does MediaCar support radio?
    By hevnsnt in forum MediaCar
    Last Post: 05-16-2004, 02:49 AM
  4. Radio Xtreme Support in Media Car soon?
    By antimatter in forum MediaCar
    Last Post: 04-08-2004, 07:09 AM
  5. Future radio support?
    By Izik in forum Media Engine
    Last Post: 04-03-2004, 05:14 PM
