Results 11 to 20 of 30
Thread: Flash Anyone?
  1. #11
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Downloading studio mx pro 2004! You need only an interface that send command as "audio", "vol+", "vol-" that you load instead of skin, it's true?
    OT to Spaghetti... where do you find your avatars???
    and... do you have Italian relatives for the choice of you nick??
    See my car and donate for spinning logos at www.ildena.it/carpc
  2. #12
    Feb 2004
    im coding in flash all the time! what do you need
  3. #13
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    yeah fyi im out of time this week, wont be able to whip anything up
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Dj_Aleks
    I just need this:
    Flash Anyone?
    I can already make it so Flash can send commands to RR, I'm trying to get RR to update Info on the Flash portion of the skin (i.e. to display the Title of a song etc).
  5. #15
    Feb 2004
    Quote Originally Posted by guino
    I just need this:
    Flash Anyone?
    seems kinda unclear there...
    you need a script that can be affected by your app?? but for that to work youll need to send variables to that flash window??
    a flash movie is made up by frames, so i cant really understand how im supposed to make a file thats able to wait for imputs and then change that depending on variables sent by your software?
  6. #16
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Quote Originally Posted by ildena
    No I'm not Italian - everyone keeps asking me that......
    As for my avatars, I extracted a whole loada piccies from a Flash advent calendar....with boobies....
    Then I edit them to make 'em small enough for the forums.
  7. #17
    Jul 2003
    Not quite with you there, but you keep the variable text box across ALL frames
  8. #18
    Feb 2004
    Quote Originally Posted by Spaghetti
    yeah, sure i can =) but thats why i asked for more specific info =) to i need to "name" the textbox or what? details details details =)
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Here's what I can do: Set the content of a variable in the flash script. So, you'll basically have to make a loop of some sort that executes the every second or so... from what I could gather, something like:
    setInterval( function() { TEXTBOX = TRACKNAME; }, 1000 )
    TRACKNAME is a variable that you do not need to define or set any value to (I'll do that from VB), TEXTBOX is whatever code or command you need to use to put the contents of the variable trackname onto the text box object itself.
    I do NOT need multiple frames or anything (single frame is fine for testing). the idea is that whatever objects (in whatever frame) could use those variables I set from VB to display information regarding song, status etc..
    I do not believe the name of the textbox or any other object matters for this, although you may have to use it in the script to "set" the text with the variable contents I passed from VB..
    Hope that helps..
  10. #20
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Guino, you must have been reading my mind! Ever since I saw the original MediaCar app over a year ago I invisioned a front end with flash enhanced graphics. I even investigated creating a complete flash app but found that the one item that I needed above all else, the eq from win amp, couldn't be controled from flash (as far as I know). Fantastic stuff!!!
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  2. 800mb Flash Drive as bootable drive
    By Tidder in forum General Hardware Discussion
    Last Post: 04-27-2005, 05:40 PM
  3. Compact Flash WIFI?
    By RedGTiVR6 in forum Wireless Communications
    Last Post: 12-30-2004, 04:17 PM
  4. Cheap Compact Flash
    By BiohazrD in forum General Hardware Discussion
    Last Post: 10-05-2004, 07:07 PM
  5. Working w/ Flash??
    By emayers04 in forum MediaCar
    Last Post: 06-01-2004, 05:53 PM
