Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: Skins vs Gamma
  1. #31
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @ Ol33l PM sent..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #32
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Blue ZX3
    Don't think you could use that one with the phidgets only cause its already connected to other componets...but maybe you could mount the phidgets one next to it..if theres not enough room for the board then just unsoldier the photocell and splice in some wire and them mount it next the other one, but you have to keep the board tied in cause theres a cap on it which is used to get the measurement...
    Who says I can't make parallel wires into the photocell? But for at-home testing, I'll need to be using one that you would provide
    UGPM
  3. #33
    Feb 2005
    Sorry, but what is 8/8/8 Phidgets kit??? Is it a Hardware kit, or a Softwarekit???
    Were can i buy this kits???
    For what are these Phidgets used???
    Sorry...but i'am a bad noob with MediaCar and my English is... more than bad;o)
    thanks
  4. #34
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by hexer
    thanks
    www.phidgets.com
    Its is a hardware that can be easily controlled through software.
    They are used for many different things, like some poeple use them for controlling their climate control system.
  5. #35
    Feb 2005
    And whats the 8/8/8 Phidgets kit??? Is it a special Kit???
    Some used it to display the temp. inside or outside the car in RoadRunner, right???
    In this thead, they wont to use it with an photocell to chance from day to night Modus in RR, right too??
  6. #36
    Jul 2004
    Berkeley, CA
    8/8/8 = 8 anaog inputs, 8 digital inputs, 8 digital outputs. the temp and photocells should be connected to the analog inputs. The rest is correct
  7. #37
    Feb 2005
    ahhhhhhhhhhhhhha
  8. #38
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by ccsnet
    Ok... my thoughts on this are...
    The button should still keep its three stages. Within the options area you select for each one on those settings disable, skin, gama setting and may be even time ? This way you can have the gamma changed, the skin or even both... keeps every one happy. And because when RR closes down and goes back to the defaults when you reboot your skin / settings should be back... I think ( unless you hibernate in which case it wont ).
    What do you all think - best of both worlds then ...
    Terran
    Gunio, for those of us with out the hardware thats been discussed in this thred are you going to impliment the above ?
    Terran
  9. #39
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Terran
    I'm working on implementing the gamma "built-in" RR right now.. it's not so hard, just messy.. anyway, I've intendet to add a day/night skin feature.. in my opinion, it should be separate, but I guess it could be made to be controlled by the gamma button as option.
    Ride Runner RR's Myspace
  10. #40
    Jan 2003
    Quote Originally Posted by guino
    I agree but don't forget there are other apps that may be used... like MM or Phone Control ( yeh all right bad examples but you know what I mean ) where having a skin switch & gamma as well is handy.
    Terran
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 07:12 AM
  2. Replies: 3
    Last Post: 12-02-2004, 01:02 AM
  3. gamma problem after hibernation
    By djkriz in forum LCD/Display
    Last Post: 09-22-2004, 10:19 AM
  4. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 05:34 PM
  5. How to get skins?!?
    By XxAndyxX in forum Software & Software Development
    Last Post: 01-19-2004, 12:53 PM
