Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
Thread: What TV tuners ?
  1. #11
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I am also looking for this... I would like:
    - tv
    - fm
    - video input for camera
    - no external power
    Is this at all possible?!?!?! (EXTERNAL USB2 Please)
    The Hauppauge seems to require power, and the one that doesnt require power doesnt do FM???
    Also, do I need to use the line in for FM audio for all cards? I wanted just USB to the computer, so I can use my input for my microphone (before I upgrade my soundcard)...
    Thanks!
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bigaaron
    I just bought a Hauppauge (read: $149) win tv usb II pvr tv and fm tuner. How can I embed it into RR? I can control the tuner with my minikey, do I just need to assign keyboard keys to RR buttons? Any help is appreciated. I just want to see the tv in a RR skin with basic up and down channels or stations. Same thing for the FM tuner.
    To set up any TV Tuner in RR:
    -Install the TV plugin -- see my site (scroll down on main page)
    -Get a skin with TV support -- Brushmetal update does
    -Go in winamp (Alone), press 'configure' on the TV input plugin, tell it to use "Thin Frame", and then tell it where to save presets and do a quick scan.
    -Go in RRconfig and set the location of your TV presets, when RR starts the TV, it will load them up as channels and show you the TV feed.
    To set up the radio:
    -Install Radiator
    -Configure it to work with your card
    -Run RRconfig and set the location you installed Radiator, and set it to use Radiator.. when RR starts it will start radiator and let you scan/add presets to use with it.
    I believe the hauppauge is well supported in Radiator.
    Ride Runner RR's Myspace
  3. #13
    Feb 2005
    Great, thanks!
    The Hauppauge model I have does everything through the usb cable except it needs power (6vdc) so I just used a 2000ma cigarette adaptor set on 6v and I use the amp turn on from my m1-atx power supply to kick on a bosch relay which powers up the 6v adaptor, turns on my 5ch power amplifier, my alpine eq, and my power antenna (I have a override switch to put that down if im not using the tuner). I power up the audigy nx and the usb slim dvd player from the 5v output on the m1-atx. It's all getting dialed in daily.
  4. #14
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    all you guys with the wintv pvr usb 2.0, i have a few questions... first, how are you guys powering it up in the car? and second, how are you getting TV stations? what i mean by this is, what are you connecting the winTV too? im a little unclear about the whole thing, and i wanted to add tv/radio functionality to my carpc thanks
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  5. #15
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    OK. One more question
    What type of antenna do you guys use and where do you mount it for good TV reception in the car.
  6. #16
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    I've got an Hauppauge WinTv GO with FM receiver (pci version) that I can let go for really cheap
    If anyone's interested, pm me
  7. #17
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by tolisn
    I'm very interested too, I was thinking about doing it myself, I'm looking for a good howto or a guide, anyone here with experience?
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  8. #18
    Oct 2004
    San Diego, CA
    RETRY:
  9. #19
    Oct 2004
    A question:
    the antennas diversity are compatible with the following models?
    Cinergy 600 TV.
    FlyTV First 30, FM and TV tuner.
    AverMedia TV Study 303.
    ATI All-In-Wonder.
    Hauppauge.
    Excused but little are shod in matter.
    Mar 2005
    RR Hauppauge WinTV USB2 TV Tuner Problem
    All; I have read these forums religiously to learn from others, in which I greatly have. But I am stuck and would appreciate any help anyone can pass my way. I have the Hauppauge WinTV USB2 TV tuner. I have a few of the "Brushed" skins and have applied the brushmetal update to all of them. I have downloaded and installed the Winzip plug in. I have gone into the winzip plugin and made the necessary changes. I have scanned and picked up a host of channels which i have saved under c:\TV. I dont know where the magic happens but i can not get the TV to work. As a matter of fact,I dont even see a TV button anywhere. I am assuming the TV is launched under the "Radio" tab but its not trivial. I am not running the FM section and do not have any intent to.I just want the basic TV function to work via Road Runner. Any suggestions?
  1. What is the best software for TV tuners
    By n8scstm in forum Software & Software Development
    Last Post: 12-10-2004, 04:52 PM
  2. TV Tuners/FM Tuners For MCE2005 (Need Opinions)
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 11-05-2004, 03:48 PM
  3. PCI/USB TV Tuners?
    By acura cl in forum General Hardware Discussion
    Last Post: 05-31-2004, 04:21 PM
  4. Tv Tuners
    By skassama in forum General Hardware Discussion
    Last Post: 10-13-2003, 11:01 AM
  5. Replies: 2
    Last Post: 09-21-2002, 10:48 PM
