Results 21 to 30 of 37
Thread: What TV tuners ?
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by aseraj
    All; I have read these forums religiously to learn from others, in which I greatly have. But I am stuck and would appreciate any help anyone can pass my way. I have the Hauppauge WinTV USB2 TV tuner. I have a few of the "Brushed" skins and have applied the brushmetal update to all of them. I have downloaded and installed the Winzip plug in. I have gone into the winzip plugin and made the necessary changes. I have scanned and picked up a host of channels which i have saved under c:\TV. I dont know where the magic happens but i can not get the TV to work. As a matter of fact,I dont even see a TV button anywhere. I am assuming the TV is launched under the "Radio" tab but its not trivial. I am not running the FM section and do not have any intent to.I just want the basic TV function to work via Road Runner. Any suggestions?
    Read the TV Faq... in any case, I'd download the Full brushmetal skin from my site, then download the update on topo of it.. you should see the "TV" button in the main menu then... once that's there and the settings in RRConfig are set, you should be able to view the TV channels you setup -- as long as it worked in the TV plugin.. if by any means you have the updated brushmetal skin and you don't see the TV button, type in (keyboard): "TV" (including quotes) while the main menu is on, and it should bring the TV .. if not, you definitely don't have the skins needed..
    Ride Runner RR's Myspace
  2. #22
    Mar 2005
    Guino!
    Thanks for the heads up! Your idea worked...as expected! Thanks again. I went to your site and downloaded the BrushMetalBlue.zip and installed the BrushMetalUpdate on top of that and sure enough, the TV icon appeared! However, driving a 350z, a spinning honda emblem doesnt look to styling. How do i change that to a "z". Actually it doesnt even have to be spinning. Here's a site with all the different emblems: http://febsperanza.3plast.com/ under media car skins > brands.
    Thanks!
  3. #23
    Mar 2005
    Guino!
    Just wanted to let you know I think i figured it out..I found Ildena's posts and downloaded a nissan.swf file. Then i put that in the brushmetal skin folder and changed its name to logo.swf. Before i knew it,i had a spinning nissan. I still would rather have a stationaty "Z" so I have some more playing to do. Just didnt want to waste your time on something i figured out.....Thanks again for the heads up!
    Regards
  4. #24
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    AverTV sound Problem
    Quote Originally Posted by guino
    To set up any TV Tuner in RR:
    -Install the TV plugin -- see my site (scroll down on main page)
    -Get a skin with TV support -- Brushmetal update does
    -Go in winamp (Alone), press 'configure' on the TV input plugin, tell it to use "Thin Frame", and then tell it where to save presets and do a quick scan.
    -Go in RRconfig and set the location of your TV presets, when RR starts the TV, it will load them up as channels and show you the TV feed.
    Guino I'm trying out an AverMedia AverTV USB2.0 PLUS, which is a TV only external USB device. I've got the device running OK on it's own software. When I run your recommended TV plugin to Winamp through RR I have presets running sucessfully, but can't get any sound. It uses the WAV device when running on it's own software. Can you help ?
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  5. #25
    Variable Bitrate MC_Stoo's Avatar
    Jun 2004
    Manchester, UK
    I've not really considered TV before but I have a WinTV Theater PCI card which has built-in FM tuner. Anyone know if this is likely to work?
    Googled technical crap enclosed...
    37284 Rev. B421 "WinTV Theater"
    Chips: bt878a, msp3410d-b4, dpl3518a-a2, hef4052bt, 24wc02, pic16c54, tda1308
    Connectors: FM, TV, Audio out (8pol), DTV/SVid (7pol), Line In, IR
    The Audio out needs a special fanout cable ("A/V Kabel") with these connectors:
    3,5mm Klinke (Stereo Line out), yellow cinch (Composite Video In); black cinch (Center out), white cinch (surround 1), red cinch (surround 2)
    pcb: 370000-03 (c) 1999
    Note: onboard connectors: "P1" is Line-Out (not documented in manual, though.)
    Audiopath for P1: same as 61334
    bttv0: Bt878 (rev 17) at 00:11.0, irq: 11, latency: 32, mmio: 0xe4101000
    bttv0: gpio: en=00000000, out=00000000 in=00ffffdb [init #1]
    msp34xx: init: chip=MSP3410D-B4, has NICAM support
    eeprom -x
    0000 84 12 00 00 05 50 0e 7f 04 15 23 a4 91 91 44 89 .....P........D.
    0010 00 00 00 00 05 84 0a 00 01 01 20 77 00 40 04 16 ...........w....
    0020 3a 00 74 02 01 05 03 79 01 00 00 00 00 00 00 00 ..t....y........
    0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0070 00 00 00 00 00 00 00 00 00 00 00 00 13 eb 00 70 ...............p
    0080 84 12 00 00 05 50 0e 7f 04 15 23 a4 91 91 44 89 .....P........D.
    0090 00 00 00 00 05 84 0a 00 01 01 20 77 00 40 04 16 ...........w....
    00a0 3a 00 74 02 01 05 03 79 01 00 00 00 00 00 00 00 ..t....y........
    00b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00f0 00 00 00 00 00 00 00 00 00 00 00 00 13 eb 00 70 ...............p
    PCI Vendor ID: 0x0070, Subsystem ID: 0x13eb
    Decoding Hauppauge EEPROM:
    Model : 37284
    Revision : B421
    Serial : 3806724
    Tuner : Phillips FM1216
    Tuner Formats: PAL(B/G)
    Ext. Inputs : 3
    Svideo : yes
    Audio : MSP3410D
    Audio Outputs: Internal and BackPanel
    Decoder : BT878
    Video Formats: NTSC(M) PAL(BGHIDK) SECAM(L/L) PAL(M) PAL(N) NTSC(443) PAL(NCOMBO)
    Videotext : Yes (Software)
    Radio : FM
    Infrared : yes
    Checksum : 1 [OK]
    EEPROM:
    84 12 00 00 05 50 0e 7f 04 15 23 a4 91 91 44 89 00 00 00 00 05
    84 0a 00 01 01 20 77 00 40 04 16 3a 00
    74 02 01 05 0
    79 01
    detect
    0x30: Hauppauge IR (pic16c54 onboard)
    0x80: msp34xx/tea6300 sound processor
    0x84: ???
    0xa0: eeprom (bt878, Hauppauge-848)
    0xc2: tuner
    DC UK Forum
  6. #26
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by wizz
    Wizz
    Go into the TV Plugin's Audio Tab and try to choose that audio device of your card to see if the sound starts with it.. otherwise, you may have to hook a line in cable onto it..
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by MC_Stoo
    Very likely to work...
  8. #28
    Nov 2004
    Leicestershire UK
    Did that....as per pic.
    This device doesn't have a line out. It only has USB and A/V in.
    Wizz
  9. #29
    Variable Bitrate M^ck^y's Avatar
    Aug 2004
    Melbourne
    I have in fact asked many times what tv tuner and antenna to get in different threads here.. no one has ever been able to give a clear answer
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It is hard to tell.. for the TV Tuners, the requirements (to be sure it will work) are:
    -WDM Interface support (Most cards do)
    -Line OUT output so you can PHYSICALLY connect the audio to your sound card
    Antenna is really up to you.. I have no TV in the car, so I woudn't know.. in fact, I don't know of many people who have TV antennas in their cars...
  1. What is the best software for TV tuners
    By n8scstm in forum Software & Software Development
    Last Post: 12-10-2004, 03:52 PM
  2. TV Tuners/FM Tuners For MCE2005 (Need Opinions)
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 11-05-2004, 02:48 PM
  3. PCI/USB TV Tuners?
    By acura cl in forum General Hardware Discussion
    Last Post: 05-31-2004, 03:21 PM
  4. Tv Tuners
    By skassama in forum General Hardware Discussion
    Last Post: 10-13-2003, 10:01 AM
  5. Replies: 2
    Last Post: 09-21-2002, 09:48 PM
