Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: What TV tuners ?
  1. #31
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by wizz
    Did that....as per pic.
    This device doesn't have a line out. It only has USB and A/V in.
    Wizz
    In that Mixer Line setting, did you try looking for a TV Audio line or something like that ? if the Tuner added a sounds device to your system, it should be listed in there... and you should be able to have the plugin or RR unmute it when usint the TV..
    Ride Runner RR's Myspace
  2. #32
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by guino
    Unfortunately it hasn't added another sound device. I've not bothered with another pic because the list consists of no more than is in the volume control properties on the task bar.
    As explained earlier, when the tuner is running in it's native software I get both picture and sound (albeit out of sync somewhat, probably a CPU power issue) and the sound mutes if I mute the WAV in volume control in the taskbar.
    I think I may have to give up on this one and accept there might be an incompatibility issue with this device, although I notice another model from Aver works fine.
    Any more suggestions are welcome.
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  3. #33
    guino's Avatar
    Nov 2004
    Toronto, Canada
    not yet.. try going on Winamp's TV plugin, load a/some preset(s) onto the playlist and start the TV (outside RR that is).. then while the tv is on (without sound), try going into the sound recorder from windows and try to record something.. you may want to play around with the mixer's RECORDING settings to see if you're able to record the TV audio by any chance.. if it works with some setting, then it may be possible to pull up the sound for your tv...
    It'd be weird that a TV card would have WDM interface but no way of pulling up the audio without using the manufacturer's application..
  4. #34
    Low Bitrate Alex121's Avatar
    Feb 2005
    Gold Coast, Australia
    um sorry if this is stupid but what is RR?
    thanks
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's a open source MediaCar front-end clone.. there are many FAQs you can read on the RR FAQ sub-forum..
  6. #36
    Nov 2004
    Leicestershire UK
    Please refer to:-
    Winamp TV plugin 1.9beta6 has been released
    YES, YES, YES.
    Wizz
  7. #37
    guino's Avatar
    Nov 2004
    Toronto, Canada
    nice to know it works ..
  1. What is the best software for TV tuners
    By n8scstm in forum Software & Software Development
    Last Post: 12-10-2004, 04:52 PM
  2. TV Tuners/FM Tuners For MCE2005 (Need Opinions)
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 11-05-2004, 03:48 PM
  3. PCI/USB TV Tuners?
    By acura cl in forum General Hardware Discussion
    Last Post: 05-31-2004, 04:21 PM
  4. Tv Tuners
    By skassama in forum General Hardware Discussion
    Last Post: 10-13-2003, 11:01 AM
  5. Replies: 2
    Last Post: 09-21-2002, 10:48 PM
