Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 124
Thread: RR 2-20-05 ... Bug Fixes ...
  1. #101
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Here you go:
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  2. #102
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well.. trying to solve your issue, I actually figured out why the logo spins like crazy in some computers... The version of the flash in the machine is what does that..
    I recommend you try the following:
    -download: http://rmc.pimpedwheels.com/Flash.zip
    -Unzip it into Windows\System32
    -Click Start->Run, enter: CMD (and hit Ok)
    -On the text window, type in (each line followed by enter):
    CD\Windows\system32
    regsvr32 Flash.ocx
    You should see "....succeeded", if so, close that window and try RR again.
    This should also fix the problem of the logo spinning too fast -- I tried it.
    Let me know if it still doesn't work..
    Ride Runner RR's Myspace
  3. #103
    Feb 2005
    The Yay Area (SF)
    WOW! How did you know so fast? What exactly happened?
    Thanks so much for your help! I'll be donating soon I promise!
    Tay
  4. #104
    guino's Avatar
    Nov 2004
    Toronto, Canada
    some machines just have the flash support from microsoft (older version). All I did was post the new version and tell you how to install it..
    Glad to help
  5. #105
    Feb 2005
    Im a newbie and trying this out for the first time. Your app looks awesome, got the video and audio working great. havent shelled out bucks for GPS yet.
    Question though...I cant launch any application from the apps window. like calc or anything else I put in there to test with. Sometimes I can get the calc jpg but the app itself wont launch (If I double click or hit 'launch', same result...nothing). Is this a known issue or am I doing something wrong?
  6. #106
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by shmoe
    Typically this means the path to the application on your Launch INI file is incorrect.. you should edit the INI files for the apps you wish to run and make sure they are correct along with their window titles. If the path is wrong, it won't run. If the windowtitle is wrong, it will run but you may not see it because it will not embed. I have not had any issue reported with the latest versions of RR regarding the launch screen -- in fact, lots of people use it.
  7. #107
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Not sure if you have got this one... really hammered RR while I was away this week. Noticed the hide mouse problem ( which I see you have fixed ) and also when hibernating or starting the app the play type ( repeat / random ) is always ramdom only when the app restarts. I thought it was just me so I checked the setting in the config and it said last - as a result I tested this by leaving it in number of modes and each time after been in hibernation ( at least ) it still defaulted back to the random setting.
    Terran
  8. #108
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't mess with the repeat/shuffle after hibernation.. but I can definitely force it to the last settings..
  9. #109
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i found an interesting bug in girder.... sometimes when i hit "1" or "6" , instead of changing to different areas in RR, it completely closes out RR and winamp still plays the song, but i cant get back to RR, i have to end task to both rr.exe and winamp.exe and start over (which is a pain and def. dangerous while driving) i wonder why its doin that...
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  10. #110
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll look at it.. haven't done much testing with girder after the navigation code was re-buit.
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
