Originally Posted by shmoe
I not getting this. I created a folder called launch in c:\program files\road runner. Set c:\program files\road runner\launch as the launch path in rr.ini, I then placed the jpg and ini (such as calc.ini) into it. Launch RR and hit applications and I get .. in the window. No apps listed. If I hit the double up arrow I see a calc jpg but cant launch it (checked the task mangler to see if maybe it was running but hidden...nothing). As a test I copied the path from the calc.ini file into run and it opened up the calc, did the same with the windowtitle, no problems.
There must be a step somewere I'm missing. If this works for other people, where are they putting the .exe's? are they putting anything other than a jpg and ini file in the launch dir? Is there some other file that needs to be modified to tell RR to allow an embedded app?
