Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 124
Thread: RR 2-20-05 ... Bug Fixes ...
  1. #111
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by guino
    I don't mess with the repeat/shuffle after hibernation.. but I can definitely force it to the last settings..
    Errr.... OK - so whats this sposed to do then ?
    Terran
    ( Please if you can sort the setting after shuffle it would be much appciated - the setting defaults to Random which is a pain if you listing to an album or book )
  2. #112
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    Quote Originally Posted by Chita79
    just about all thye buttons have done that to me one time or another
    Is this fixed in the newest version? I have to push almost every button twice
  3. #113
    Feb 2005
    applications problem
    Typically this means the path to the application on your Launch INI file is incorrect.. you should edit the INI files for the apps you wish to run and make sure they are correct along with their window titles. If the path is wrong, it won't run. If the windowtitle is wrong, it will run but you may not see it because it will not embed. I have not had any issue reported with the latest versions of RR regarding the launch screen -- in fact, lots of people use it.
    I not getting this. I created a folder called launch in c:\program files\road runner. Set c:\program files\road runner\launch as the launch path in rr.ini, I then placed the jpg and ini (such as calc.ini) into it. Launch RR and hit applications and I get .. in the window. No apps listed. If I hit the double up arrow I see a calc jpg but cant launch it (checked the task mangler to see if maybe it was running but hidden...nothing). As a test I copied the path from the calc.ini file into run and it opened up the calc, did the same with the windowtitle, no problems.
    There must be a step somewere I'm missing. If this works for other people, where are they putting the .exe's? are they putting anything other than a jpg and ini file in the launch dir? Is there some other file that needs to be modified to tell RR to allow an embedded app?
  4. #114
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ccsnet
    Terran
    I've added that to the code already.. wait for new version..
    The setting on RRConfig is for start/shutdown of RR only. When using hibernation, the shuffle/repeat is supposed to remain unchanged..
    Ride Runner RR's Myspace
  5. #115
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by shmoe
    You must create subfolders within the launch folder for each app you want to run.. this is heritage from MediaCar.. for calc for example, you'd create a subfolder called "CALC" then add a jpg called CALC.JPG into that subfolder, then on top of that, you need to make a file calle CALC.INI with the following contents:
    [GENERAL]
    PATH=C:\WINDOWS\system32\calc.exe
    WindowSearchString=calc
    Only the JPG is optional. If the path or window title is wrong, or if the names of folder/INI/JPG don't match, it won't work/show.
  6. #116
    Feb 2005
    BINGO!! Thats the solution...calc and notepad embed and work great! I've never used mediacar so I wasnt aware of the file format requirements. Thanks for the quick reply.
    BTW, the reason I wanted to launch other apps is because I wanted to add a blind spot camera to RR. I found a standalone webcam player and sucessfully integrated it into RR. Embedded it and everything, works awesome! Any way I can get RR to run that app on startup?
    Thanks much
  7. #117
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can run anything you want on startup.. just need to create a command to launch it... to launch it in the launch screen at startup will be tricky.. you'll probably need an extended command que (that I'm adding to the new version) in order to do that..
    The other option you have is use the TV screen. You can configure the TV plugin to use your webcam and then going into the TV screen would bring that up.. if you then wanted to have that load at startup, you could simple enter "TV" (no quotes) in the start command field in RRConfig.
  8. #118
    Feb 2005
    I considered that but it may be over my head. Im not a programmer and dont even know how to open you source code.
    That having been said, Id love to learn. Any advice on how to tweak the TV plugin? Nothing in the folder jumped out at me as having anything to do with TV.
  9. #119
    Feb 2005
    Also is it possible to get RR to open fullscreen when Im 1024x768? Right now I can only do it in 800x600.
  10. #120
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The plugin needs only a few settings to work with a webcam, you must basically disable the crossbar with audio and caption capture made for TV, then select the source device (webcam). Then go on "scan" and add the "channel" for our webcam. It is a little more complex than having your app running enbbeded... it just looks cooler
    Anyway, to run RR in any specific size, go into the folder of your skin(s) and edit the general.ini file to define the size you wish to view the skin with. The two settings are showheight and showwidth, just set them with your resolution and you should be set... as a reminder expanding JPGs is probably going to reduce the quality of the images ..
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
