Page 13 of 13 FirstFirst ... 345678910111213
Results 121 to 124 of 124
Thread: RR 2-20-05 ... Bug Fixes ...
  1. #121
    Feb 2005
    Where do I go to make those modifications to the tv plugin? Is it a file I need to modify or do I need to crack open your binaries? I havent seen the scan option anywhere either.
  2. #122
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's no scan "button" on the skins yet... we have to wait for a skin that supports it.. I have tested it only by changing the code of a button on a skin.
    For the TV plugin, you must configure it in winamp first, without RR.
    This is the plugin:
    in Winamp, you should go into preferences and "Input", then select the TV plugin and hit "Configure", you should select your webcam in the device box, then select input pin="preview" and output="thin frame", don't worry about any errors you get during this setup phase. At last on the "scan" tab you should select where to save your "channel" files (it should be an empty folder) and then click add manually to create the "channel" file for the webcam. once you do this and set RR to use that folder of the "channel" file, you should be able to get the TV screen in RR to open the view of your webcam.
    Ride Runner RR's Myspace
  3. #123
    Feb 2005
    Dude I cant believe this...this thing is AWESOME!!! Now I HAVE to build a small PC for my car, no getting around it...this is EXACTLY what I was looking for!
    Count on a donation.
  4. #124
    Jul 2004
    Quote Originally Posted by Mr.Fabio
    Just downloaded and tryed at home. Only one problem found on this release. The font size results to be too big. Some texts overheads others... Why?
    How did you make the lower bar (that shows GPS strength and other info) disappear?
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
