You can make the info bar disabled by default in MM, just run its config.Quote:
Originally Posted by Mr.Fabio
Printable View
ExactlyQuote:
Originally Posted by aguila
That probably IS the problem.. Windows will not let me select a font that is different than the current charset selected.. I have just tried it here, and when I switch to english (and re-run RR), it works fine..Quote:
Originally Posted by holistic
In any case, I'll add two options to RR:
1-Disable Internationalization
2-CodePage Selection (System, Western, Hebrew, Greek, etc)
That way, we can all be happy.. :)
thx dear god.. it was killing me.... but the weird thing is... it displays the font correct in the playlist ... it's only on time, mp3 info, temp, etc. that it screws up
I have MM final release.Quote:
Originally Posted by guino
RR 2-20.
Brushedmetal Guino full release downloaded with update.
Test:
Open RR
Launch MM
Exit to MM (not with X but ->)
Launch audio player
Reopen with button created in audio player the MM (pre open)
All ok
Close MM whit ->
Close RR with Exit main button
Close all , but error of MM displayed.
Test
Reopen RR
Launch MM
Displayed bad MM (see the screenshot)????
Mauri
What Kind of error from MM are you getting ??Quote:
Originally Posted by mauri
See the screenshotQuote:
EDIT:MM after the error don't diplayed embedded to MM correctly.
Restar the PC ,and OK.
Same procedure posted, same error......etc.... :rolleyes:
Mauri
Do you get the same error when closing MM with the X button in RR ?Quote:
Yes , the same error.Quote:
Seems like MM is not taking kindly of the "close" command.. funny enough, the SDK command to close MM doesn't work either.. :( I'll look into it..Quote:
For now, I'd suggest you to set Map Monkey as external GPS and set it as default to run External GPS, with the window title "Map Monkey -" (no quotes) it should work like it used to on prev. versions.
