Well mine is working fine and the closing of MM works great too.
That's weird all right.. I'm starting to think I should just leave MM alone.. that is, not close it at the end... the SDK for mapmonkey has a "close" function that doesn't work and apparently trying to close it manually is also giving issues..Originally Posted by chuckster
Ride Runner RR's Myspace
Tested temperature and close MM whit X (post yesterday).Originally Posted by guino
Don't work ok , temp. displayed it exsample 1973,00C (real 19,73C)in RR use (ok to Ypert.)![]()
Same problem and error for the problem of close MM , to close displayed the error posted in the screenshot yesterday
To reopen RR and launch MM, same problem of visual the skin to MM embedded RR posted in my screenshot yesterday
I use 20-2 MM update whit binary fix and extra line
disableinternat=true
in MM.ini.
The comma and not the real problem??
EDIT: my hardware to read the temp work correctly, make a new bord, tested it, and in the future posted the all packet (voltmeter and reader temp.) so each is able to build alone home made, without spending a lot of money.
You are hardly able to make , Guino, implements the serial voltmeter, so i make the tests with RR.![]()
Mauri
I'll double check this... and try another approach with MM...Originally Posted by mauri
The Audio Browser on top Video Browser bug has come back this time if you press browse list twice it land it also starts overlapping the audio from Audio Player to Video Player.
ditto....![]()
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Guino, have you checked on the id3 tag prob? just check'n hopefully you didn't loose that paper again...Thanks...more money comming your way soon...
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
when i try to play a vob file from a dvd ripped in ifo mode using dvdecrypter, a second instance of mpc opens, and the dvd does not play. all i see is the black screen for mpc. when i click on roadrunner in the taskbar, the roadrunner video window pops up briefly but disappears very quickly. if i'm quick enough i can click on the "back" button and get back to the main menu, but one instance of mpc stays open.
i don't really care about this as i don't usually watch dvd's ripped to my carputer's hard drive but i just thought you might like to know about it.
I didn't loose the paper, I have looked at it but I can't find any problem with it.. If anything, I'd like to see your RR.INI file of when you're trying to use the album info... let me know..Originally Posted by Blue ZX3
