Originally Posted by guino
Here it is!!![]()
He's traveling due to work, I think he mentioned that we should have an update possiblly on friday...but he still checks here just to see if anyone needs help....
Keep up the, what words can not describe, job!![]()
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Here it is!!![]()
I have noticed that random, when I launch the DVD mode, the temp. is read as in the screenshot.
When this MPC happens it stops RR, and it needs to use Task Bar Manager to close RR.
Reopening RR returns all ok.
Mauri
The size of the Temperature label may be too big in the skin and that is probably causing you to "click" the label when clicking "exit" and that only swiches the temp from C-F or F-C without exiting.. I'll look at the skin, as I changed it in the last minute..Originally Posted by mauri
Ride Runner RR's Myspace
As I supected, your label line is correct -- except that you have MDM instead of MBM... (it's a B!). change that and it should work ...Originally Posted by DjBac
anyone else here having the issue where buttons get stuck pressed and you have to "unpress" it to be able to hit it again? there is some button refresh issue, its not responsive to touch that well anymore... hmmm (btw...frodo works fine, so its not my touchscreen)
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
The button sticks in the "pressed" position ? Any specific button, or all of them ? Which skin?Originally Posted by Chita79
OoooopppsssOriginally Posted by guino
Thanx once more!!!![]()
Sorry I'm a NEWB, but I'm having problems getting videos to play. I browse and find one and then select it, press play and I get a black screen with a scrollbar at the bottom that isn't moving. I have to close media player to get back to roadrunner afterwards...I'm not sure what's goig on. It seems like it's stopping right after I hit play.
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
just about all thye buttons have done that to me one time or another
