not yet..Originally Posted by Passe
but, "it's a matter of time" heheheheh
Is the Gamma AutoSwitch working for internal gamma ??? (AutoSwitch, DayTime, NightTime parameters in general.ini)
Seems that when i start RR after the NightTime it does not set Night Gamma...
Ride Runner RR's Myspace
Originally Posted by guino
You've been coding too much! That was bad.![]()
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
Why not just use GammaControl? Configure it with the navivoice config utility.
Its got gamma correction based on your coordinates![]()
Yes I know, but GammaControl forces me to night gamma if i select AutoGamma, I can not go back to day gamma even if I want to...Originally Posted by 0l33l
Besides, i have software that modifies the times in general.ini, so I would prefer it to work like it used to in MediaCar (AutoSwitch at at certain time, but you can switch manually also).
I'll add those features in the future version.Originally Posted by Passe
i'm a big fan of gammacontrol because of the fact that you never have to adjust the time. you set it once and it just does it's job.
also, gammacontrol is capable of doing auto and manual through command line. in frodoplayer i set up 3 menu buttons like this:
day gamma -> gammacontrol.exe /day /exit
night gamma -> gammacontrol.exe /night /exit
auto -> gammacontrol.exe
with "autogamma based on time" enabled, these three buttons do exactly what is being described in this thread. the only problem with trying to do the same thing in roadrunner is that the function of the day/night button doesn't exit gamma control after setting the gamma. if the day/night button would set the gamma and then exit gammacontrol, we could leave gammacontrol on "auto mode" and skin another button for "auto day/night".
by the way, does anyone know how to access gammacontrol's default setting via command line. all i know is /day /night /exit. /default doesn't do anything for me.
Command line options:Originally Posted by kuo
'/day - Day Gamma Settings' + #13 +
'/night - Night Gamma Settings' + #13 +
'/original - Normal Gamma Settings' + #13 +
'/updateoff - Tuns off time based gamma updates' + #13 +
'/updateon - Tuns on time based gamma updates' + #13 +
'/switch - Switches gamma' + #13 +
'/hide - Hides GammaControl' + #13 +
'/show - Shows GammaControl' + #13 +
'/exit - Exits GammaControl', 'GammaControl', 0);
I don't see a "default" setting. This is from v.7. Its build is in the latest navivoice release![]()
Guino, any progress on this ??? I really would love to have this working...Originally Posted by guino
I thought of working on this today, but didn't get to it.. I hope do do something with it tomorrow..
