Results 1 to 4 of 4
Thread: embed Winc in Road Runner
    Sep 2002
    Switzerland
    was anybody able to embed Winc in Roadrunner?
    it fails to find the right window. after it loads winc it focuses on a gray screen saying "static" on it. anyone got an idea how to solve that?
    cheers
    pascal
    current
    2001 Chevy Tahoe
    Carputer MK 3
    - Mobo out of Shuttle Barebone System
    - AMD Duron 1300
    - 7" Lilliput
    - Opus Powersupply
    - MediaCar
    earlyer installs
    1996 Ford Explorer Carputer MK 2
    1997 Subaru Impreza GT Carputer MK 1
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What's winc ? Have you tried using WinspectorSpy to find the window information ? It's probably embbeding the wrong window with the same title.. if you use winspectorspy, you should be able to set the window title (search string) in this format:
    !<WINDOWCLASSNAME>!<WINDOWTITLE>
    For instance, the AVS window of winamp is set using:
    !Winamp Gen!AVS
    This specifies both the class name and window title to prevent embbeding of the wrong window, so you should be able to embbed the correct window ....
    Ride Runner RR's Myspace
    Sep 2002
    Switzerland
    thanks, this really helped.
    i've downloaded Winspector and then run it on my home pc. i have found out that the main window class name seems to be different all the time, so i decided to only select the most valuable part, because it had a static name.
    to my big surprise, it now does exactually what i originally wanted it to do: it embeds the whole application (don't worry about the window frame you see, it isn't really a real frame, they did a strange thing in order to make the software (or say it's border) skinnable, so this is no windows border, it's a special winc skin .. (stupid if you ask me) )
    btw: the frame around everything is from vnc, since i'm accessing my carpc from inside my home
    here is my ini file in order to load winc:
    [GENERAL]
    PATH = C:\Program Files\Cirond\Cirond Winc\Winc.exe
    TryEmbeddedTimeOut = 5
    WindowSearchString= !AfxMDIFrame70!Winc
    to finally answer your question: winc is a need little utility which connects automatically to open wireless networks and displays some details about them.
    and here's the screenshot:
    current
    2001 Chevy Tahoe
    Carputer MK 3
    - AMD Duron 1300
    - 7" Lilliput
    - Opus Powersupply
    - MediaCar
    earlyer installs
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Cool.. glad to help
  1. Road Runner Installation Program
    By bry21317 in forum Road Runner
    Last Post: 01-29-2008, 10:22 PM
  2. Why have you switched to Road Runner?
    By more mods in forum Road Runner
    Last Post: 02-21-2005, 03:48 PM
  3. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
  4. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 01:30 AM
