Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 80
Thread: RR 2-23-05 .. Quick Update..
  1. #31
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Deepgear
    I do not know, if it is a Bug, or a problem with my Xp, but:
    I can write every Font in my skin-files, but RR always displays the same Standart-Font.
    I have tested more than 10 working fonts, but every time RR displays the standart.
    In word the Fonts are working very well....
    Could someone help me, I am In writing a new Skin
    e I think RR is looking for the font, but can not find it. I use Xp-SP1...german version
    Run RRconfig and check the "disable internationalization" option. it will make it so RR will use the exact font you specify in your skin files.. otherwise, RR will only allow you to select a font that accepts the default charset of your system (german, greek etc).
    Ride Runner RR's Myspace
  2. #32
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    hey, sorry, but not really sure where to ask this...
    Is there a 800 X 480 version of the brushed metal RR coming?
    Thanks!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  3. #33
    Feb 2004
    Quote Originally Posted by guino
    THX THX THX,
    Guino if you were a girl......
    Doesnt matter......
    If you come to the 2006 Europe Road Trip, lets get some drinks, I'll pay !!
  4. #34
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by contaygious
    Thanks!
    Not that I know of, although you can use the current brushmetal skin with a very simple change:
    -Open the general.ini file of the 800x600 brushmetal skin.
    -Where it says "showheight" change it from '600' to '480'
    -Save the file and Run RR -- It should be in 800x480.
    -You might want to edit the .skin files to tweak the areas of fonts etc (if you think something could be improved.
  5. #35
    Any ideas on my Shutdown Problem Guino? Only seems to have done it since the 20-2-05 update.
  6. #36
    Feb 2005
    The Yay Area (SF)
    Thanks! But that didn't look too good. I guess I'll use powerstrip to change the res to 800 X 600 until someone makes a version in 800 by 480
  7. #37
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Focus Dan
    The prblem where pressing the PGDown button quits RR ? I still have no idea why this is happening with you.. it works fine for most people.. I have been adding more preventions on the lists of RR (folder/playlist).. I doubt I Can fix your problem without seeing it happening.. if you have VNC or something I could try to connect to your machine and you should what's going on..
  8. #38
    Its not the PGDown problem. When I turn off the key the PC is supposed to shutdown thanks to the Opus.. When RR is running windows fails to shutdown. If I close RR before turning off the key it shuts down fine.
    Dont have a net connection on the Car pc yet unfortunatly
  9. #39
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ohhh.. how come I never heard of this before ? I don't believe there's anything in RR to prevent the shutdown of the machine.. I have seen winamp 5 prevent the shutdown process, so if you use Winamp 5, I'd suggest you try 2.9x.. otherwise try to simply change winamp settings to prevent that from happening.. if you have a doubt if it is really winamp you should close RR, open Winamp manually, start playing a song, and then try the shutdown thing.. on my laptop it prevents it from working.. (but it does hibernate I think)..
  10. #40
    Great, will give it a go in the morning, its late here in the UK
    Never thought about winamp being the problem.. strange..
    Thanks guino
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 07:31 PM
  3. Frodoplayer Update Dec 23
    By frodobaggins in forum Software & Software Development
    Last Post: 12-23-2003, 01:58 AM
