Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 80
Thread: RR 2-23-05 .. Quick Update..
  1. #41
    Updated RR and downgraded Winamp to 2.9 and the problem persists.
    It used to work fine, seems like something from 20-2-05 has made it go like this.
  2. #42
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Does Winamp close down like it should?
  3. #43
    Yeah it seems to. RR and winamp close but nothing else does
  4. #44
    Jan 2004
    Jersey/NY
    I have the same problem with shutting down, and I'm using the 2-23 version with winamp 2.9. Using in the house right now.. hit power switch once, shuts down RR/winamp, hit it again, then it shuts down comp.
  5. #45
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by Focus Dan
    I'm having your same problem; discovered only today...
    In my car, the touchscreen is defective and sometimes in emergency case, i must shutdown the system with the power button... Tested with the 02-27 version too
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  6. #46
    Kinda glad i'm not the only one with the problem now! Was beginning to blame the hardware..
  7. #47
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok guys, I'll try to figure out what's going on.. it should take a few power offs, but heck.. hehe
    Ride Runner RR's Myspace
  8. #48
    FLAC mauri's Avatar
    Jan 2004
    Its not the PGDown problem. When I turn off the key the PC is supposed to shutdown thanks to the Opus.. When RR is running windows fails to shutdown. If I close RR before turning off the key it shuts down fine.
    Dont have a net connection on the Car pc yet unfortunatly
    Yes , this and a problem that also happens to me that use the ITPS.
    If MM and open, and i turn off the key to ignition of the car, it has to depart the automatic shutdown, but with open MM embedded to RR doesn't happen.
    Using stand alone MM instead all ok.
    Mauri
  9. #49
    guino's Avatar
    Nov 2004
    Toronto, Canada
    just a quick question.. why don't you guys set windows to "Hibernate" when using the power button, instead of using Shutdown?? It works so much better and it is so much faster.. I never shutdown my car, always hibernate.. but I guess it is an option..
  10. #50
    Never really tried it because it worked so well.. Will give it a go.. I'm not normally one for change
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
  3. Frodoplayer Update Dec 23
    By frodobaggins in forum Software & Software Development
    Last Post: 12-23-2003, 02:58 AM
