Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 80
Thread: RR 2-23-05 .. Quick Update..
  1. #51
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Hey sorry, I feel dumb, but I'm not sure how the visualization is supposed to work.
    I hit the vis button and it pops up fine in the playlist window as I specified.
    I go somewhere else and it goes away fine.
    I come back and hit the vis button again to pop it back up, but nothing happnes.
    I click it again and I see it pop up for a second and it goes away.
    I click it again and nothing happens.
    Then after a 4th click-it appears.
    Am I missing something? How exactly is it supposed to work? Sorry, this is my first experience with any carpc media interface.
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  2. #52
    FLAC mauri's Avatar
    Jan 2004
    I use to turn off the ignition key "Shutdown" by ITPS.
    But have the problem post, only if MM is open and visible to RR.
    If i use audio player and MM run open ,don't visible,i turn off the key and RR close correctly, and shutdown its ok.
    Strange.....
    Mauri
  3. #53
    Jan 2004
    Jersey/NY
    I use shutdown instead of hibernate because, well frankly, I'm sick of the instability of windows (yup, even XP). Especially since I got my boot time to only be like 5 or so seconds longer from hibernate compared to shutting down, I'd much rather just let it shut down completely.
  4. #54
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by contaygious
    When you go back into the audio player, the vis is supposed to come back up (if left ON).. if it isn't working like that, then you might just not have the correct option setup, and so, it would not be enbbeding correctly. Double check RRconfig and then make sure you have selected the same plugin in winamp, or it will not work right. If everything seems correct, let me know which plugin you're using etc..
    Ride Runner RR's Myspace
  5. #55
    Feb 2005
    The Yay Area (SF)
    Oh, ok yes it does work with mildrop sorry, I was trying to make it work with adv visualization studio v 2.81b. How do I config rr for that instead of mildrop?
    Thanks!
    Oh also, when I change the size of the mlkdrop window it just goes back to what it was before...
  6. #56
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Thanks!
    The visualization is supposed to be "fixed" at that location specified in the skin.. you can make it full screen by dbl-clicking it. If you want to use AVS, set AVS in RRconfig and run winamp (outside RR) to select AVS there as well. The AVS is a little buggy (the plugin) when resizing it.
  7. #57
    Feb 2005
    The Yay Area (SF)
    When I choose avs it automatically brings up the configure window along with the vis window.
    As for milkdrop-it doesn't fill up the whole playlist box. That's why I am trying to change the size.
    I believe the size is fixed for milkdrop by skin (not avs), but the location seems to be based on where I dragged it the last time.
    Also, the year is cut off in the date on the music screen-probably mentioned before.
  8. #58
    Oct 2004
    Talking Welcome RR
    Hi Guino,
    I am following with much interest your plan and am in order to mount in my car mine carputer.
    A question:
    I use mediacar, but I have of the problems with my DRU - 100 D-LINK in how much when I exit from the radio the "ine-in" not put in MUTE .
    I can use the radio with RR?
    If the affirmative answer e' explains to me as I make.
    I have read this radio support but they are not successful to understand a lot.
    Excuse for my bad English.
    Nov 2004
    I also have just started using Hibernate, it is so much faster for the boot times.
    I have not had any problems with it, everything seems to work fine with it.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  10. #60
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Seems the problems you're having are all related to the fact you're using 800x480.. in any case, those are things you can fix by simply editing the .skin files to define the area where to show the VIS and the area allowed for displaying the date..
    Your AVS window is showing together with the AVS editor because you have it docked, run winamp separately, undock it then re-run RR. It should work.
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 07:31 PM
  3. Frodoplayer Update Dec 23
    By frodobaggins in forum Software & Software Development
    Last Post: 12-23-2003, 01:58 AM
