This problem could be that when SA close, a modal dialogue window pop up asking you to save the current map. RR always running upfront and thus blocking that window.
How can i embed SA USA 2005? it will open the program but i cant close it or get back into RR then go back to gps with out making problems.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I'd llook for an option to prevent that question/dialog from coming up, when exiting...
Ride Runner RR's Myspace
well thats not a problem i can close it manually but when i click GPS SA comes up ifront of RR, so its not emmeded.
1990 Jeep Cherokee
You probably just need to find the correct window title/class name to embbed...Originally Posted by WebDog
how do i do that?
1990 Jeep Cherokee
For "discovering" window information, you can use a very nice simple application called Winspecttor Spy..Originally Posted by WebDog
http://www.windows-spy.com/download/
You can find the information you need by doing this:
-Install Winspector
-Run SA 2005 and make sure the window you want to embedd is visible
-Run Winspector
-Drag the red target circle (top-left) onto the WINDOW TITLE of the window you want to enbedd -- you should see a red line around the entire window.
-Now the window information is highlighted on the list of the left side of Winspector.
-Right-Click on the highlighted item and hit "Properties.." a new window comes up
-The information you need is in the two first lines of the properties window (class name and window title).
You can try to use the second line info (Title) or the first line with a '!' in front (to denote it's a class name) as the GPS Name in RRConfig. Examples would be (for the GPS Name setting of RR):
!CabinetWClass (by window class name)
My Documents (by window title)
You can also specify Both information (for a more precise search):
!CabinetWClass!My Documents
Let me know if you need more details..
Ok thanks ill try it tomarrow morning.
1990 Jeep Cherokee
hey WebDog..did you get this to work????
If you Put these lines exactly in your RR.ini file it will work:
gpspath=C:\Program Files\DeLorme\Street Atlas USA 2005\SA2005.exe
gpsname=DeLorme Street Atlas USA® 2005 - Map File 1
I have just tested this with 2005, and it is working fine, embedded. If it doesn't have the ® in the gpsname line, it won't work.
Hope this helps.
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
