Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 43
Thread: My small hardware to RR
  1. #31
    Low Bitrate F4kk3r0's Avatar
    Mar 2004
    Finland
    mauri could you please post the .HEX file for the temperature meter. PLEASE
  2. #32
    FLAC ppgt94's Avatar
    May 2001
    USA
    So is the voltimeter hardware (ready-to-go kit) available for purchase?
  3. #33
    Constant Bitrate ashgrovered's Avatar
    Jul 2005
    Brisbane Australia
    I only came across this thread today
    I want to display 3 temps in my skin, and also monitor the voltage of 2 batteries
    I had a look for Kit145 on the link Guino posted but could not find it
    Did this get off the ground
  4. #34
    FLAC mauri's Avatar
    Jan 2004
    I have posted all two my hardware, serial voltimeter + power timer for GPS, and my version of temperature kit reader,free for all, for make home made,in this forum....search in the old post.please.
    Mauri
  5. #35
    Mar 2009
    Belgrade, Serbia
    I have built serial voltmeter and it works fine. I`m planing to build temp reader too.
    How can I display just measured value, without "V"? Same question for temperature.
  6. #36
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The "V" is displayed to ensure the result is in VOLTS. Similarly, the temperature will include a "C" or "F" indicating the scale used. There's no label in RR to display just the number only (not right now at least), but we can add support for it.
    Ride Runner RR's Myspace
  7. #37
    Mar 2009
    Belgrade, Serbia
    It would be useful to leave the skin designer more freedom allowing that option. It is really not problem to add V manually if one wants to use same font, size and color for both numbers and scale. So, if you decide to add that support I`ll be glad. Thanks.
  8. #38
    Mar 2009
    Belgrade, Serbia
    Guino, could you add C if it is easier to do than left out C and V completely?
  9. #39
    Mar 2009
    Belgrade, Serbia
    As it seams to be a problem to took out the C and V from the code or at least and add before C or F I did one dirty trick. I limit the number of characters to be show for the temp reading so C is hidden. After numbers I added C so it looks right now.
    http://www.mp3car.com/vbulletin/atta...1&d=1259340453
  10. #40
    Mar 2009
    Belgrade, Serbia
    I just put a sensor in ice and discovered my trick don`t work for temperatures lover than 10C as everything shifts left and expose original C that I thought I hide
  1. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 11:44 AM
  2. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
  3. Min hardware spec for RR mp3 and Mapmonkey only
    By Caitlin in forum Road Runner
    Last Post: 02-24-2005, 01:00 PM
  4. Replies: 4
    Last Post: 02-04-2004, 10:28 PM
  5. highout, small capacity battery?
    By jshrieve in forum Power Supplies
    Last Post: 06-15-2001, 04:34 AM
