I'll add preventions before restart/power off.Originally Posted by mauri
What did you mean by the above, it takes 5 seconds to work or it doesn't work at all ?Originally Posted by mauri
Yeah, I've been messing quite a bit with the buil-in player.. it really kind of sucks, but from machine to machine you generally get a different effect...Originally Posted by wizz
I was messing with it until 4AM (my time) so if you think you may have doenloaded it before then, I'd try and re-download it to see if it works.. and if it doesn't: I'd suggest you try and download the FFDShow filters from www.ddigest.com (Divx->Software->Filters) and try again.. if it doesn't work, I'm going to HAVE to make up some tweaks for the built in player..![]()
Ride Runner RR's Myspace
I have indeed thought of that, and you CAN do it right now.. You just have to make blank buttons and define dynamic labels in the skin (like I do with Car: and Outside: -- for temps.) The problem with using "Dynamic" labels is that none of the effects used in the buttons will show onto the labels, and that includes pressing the button etc.. so really it just doesn't look all that good, but it works.. there's just not much I can do to "fix it".. I'd say chances are that if you had the PSD file to edit the label(s), that it'd look better and would be just as easy to change..Originally Posted by chuckster
Sure, it's been there all along, just where it says Time format in RRConfig, select : "HH:MM:SS" or "HH:MM" that will be military time.Originally Posted by UK_MP3Car
Yest there is... and it's already implemented, we just need to get a skinner to do it.. the only thing we need to figure out is how to remove the buttons from the bottom of MM. I'm assiming there's probably a skin setting we can use for that.. then all those buttons (AND The buttons inside MM, plan route etc) can be performed inside RR.Originally Posted by Deepgear
Also, I may have failed to say this, but you MUST enable the TCP Listening on MM to allow integration with RR's skins (open settings.ini and set listenport=9913 and enable=yes)
Video's work fine on last D/L of 2/27, but when you leave the video screen, the main RR screen appears for a split second and then the screen goes black, with no return from that state...have to re-boot OS/RR.Originally Posted by guino
PS: Aready have FFDShow & AC3 filter. The codecs were there RR just couldn't find them, but thats OK now...it's just the exit to main RR, as described above.
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
Guino wrote:What did you mean by the above, it takes 5 seconds to work or it doesn't work at all ?[/QUOTE]
No, launch Milkdrop to Audio Player of RR, run the visualization with the effects ok, but after 5/10 seconds max, hide the effect of Milkdrop and black screen to his place (i speak ONLY of the space reserved to the visualization of Milkdrop).
I use BrushMetal update.
EDIT:the blu car icon in RR skin is to use ???
I don't have tested run in my car with GPS connect and new BrushMetal update , tomorrow I make the first test![]()
Mauri
I have updated the Install to add all of the new changes as of 2/27/05. It has the updated Binaries and also the updated Skins.
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
Ok, cool, I'll try to find why this problem is happening..Originally Posted by wizz
No, launch Milkdrop to Audio Player of RR, run the visualization with the effects ok, but after 5/10 seconds max, hide the effect of Milkdrop and black screen to his place (i speak ONLY of the space reserved to the visualization of Milkdrop).Originally Posted by mauri
Mauri[/QUOTE]
Wierd, have you tried another Vis (AVS/Tripex3) ?
The Cop car is supposed to be hidden, until you go over the speed limit set in RRConfig. Then when you get to that speed it starts blinking to warn you that you're over the speed limit.. that voice warning was just way too annoying..
