Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 80
Thread: RR 2-27-05... LATE Release (Fixes)..
  1. #51
    Variable Bitrate MC_Stoo's Avatar
    Jun 2004
    Manchester, UK
    Quote Originally Posted by ccsnet
    ... its bound to be me...
    It's me too
    DC UK Forum
  2. #52
    Feb 2004
    Quote Originally Posted by guino
    Yest there is... and it's already implemented, we just need to get a skinner to do it.. the only thing we need to figure out is how to remove the buttons from the bottom of MM. I'm assiming there's probably a skin setting we can use for that.. then all those buttons (AND The buttons inside MM, plan route etc) can be performed inside RR.
    Also, I may have failed to say this, but you MUST enable the TCP Listening on MM to allow integration with RR's skins (open settings.ini and set listenport=9913 and enable=yes)
    Ok Guino, I found a way.
    I simply made the main_bar.jpg of MM 1dot hight... thats it.
    Could you please give me the cmmands I need for menue and so on ?
    Thx
    Deepgear
  3. #53
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Dumb question time... set my night skin and day skin up but when I press the day night button only the Gamma changes... its bound to be me... just not sure what.
    Cheers
    Terran
    I haven't tried it yet, but there is a new skin command for day/night skin. Look in the text about skin commands.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
  4. #54
    Jun 2004
    Manchester, UK
    So in other words, we need to
    DC UK Forum
  5. #55
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by MC_Stoo
    This is what happerns when you just download the binarys lol.
    Mmmm So I need to change the skin again, looks like I'll have to use the internal gamma thing then.
    Terran
  6. #56
    Jan 2003
    Two bugs....
    1) Internal gamma does not work for some reason... checked my files against the orgoinal MC ones
    2) When you switch with the new command the main screen looses font info... ie at the top of mine I use the LCD font. It turns to arial I think instead. Tested this manually and works fine.
    3) Again the gamma does not work either using the skin switch function. I'm working on the basis that it is sposed to read the info from the general file.
    Cheers
    Terran
  7. #57
    Constant Bitrate holistic's Avatar
    Feb 2005
    Denmark
    does the same here... but not everytime only once in a while.... but on mine it dosent reset to arial it displays the arial font on top of the original font
  8. #58
    Mar 2004
    I had a chance to use and I missed it!
    Progress Meter:
  9. #59
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Deepgear
    Thx
    Deepgear
    The list of Commands can be found in Map Monkey's Help file (Development folder) -- The section you want is under Reference->Winsock->D3Request.
    Instead of what you might think, there's no way to pull up those "predefined" menus from MM. So what you need to do is make a Menu/Skin file (like the exit menu in the brushmetal for instance), that is shown when you press a button in RR (say to be equivalent to the "menu" Button of MM. then on this menu's buttons you'd make the commands be like "MM;Destinate_Address||EXIT", "MM;Destinate_Favorites||EXIT" etc.
    The "||Exit" in the end makes it so the menu is closed after executing the MM command to display the dialog you've requested. You may want to swap the order of the commands (just try it) to say: "EXIT||MM;Destinate_Address" ..
    Ride Runner RR's Myspace
  10. #60
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Two bugs....
    Cheers
    Terran
    The Internal Gamma only works if the general.ini file has the Day and Night Gamma Info. It is completely unrelated to the skin switch command.
    Maybe you want to send me your general.ini file to take a look (or compare it with other ones you have). Have you tried a different skin at all ?
    Also, on the skin switch font problem.. can you test to see if switching the skin in the skin browser always works or has the same bug ? I don't think I have seen that before..
  1. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
