Page 8 of 8 FirstFirst 12345678
Results 71 to 80 of 80
Thread: RR 2-27-05... LATE Release (Fixes)..
  1. #71
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mikymix
    hi Guino,
    Is there the possibility to save current playlist with name and recall it.
    If you mean, press a button, show a OSK then name the playlist, and save it (for later loading from browser): this is a feature that will be added at some point.
    Ride Runner RR's Myspace
  2. #72
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Tsleon
    Resume music doesn't work if I shutdown pc. If I exit from RR and start RR again it works, but not if I shutdown pc. In RR config I use option resume allways.
    Ok, I've figured out the problem here.. When shutting down/restating the PC, (by power button or Window's menu). Windows starts closing applications at it's own will, meaning it closes winamp and RR. Well, the problem is that winamp MIGHT close first, and if that's the case, RR will have no way of knowing which song and where winamp was playing before it got closed out. so when it restarts, chances are it will not be able to resume.
    I am not sure if there's an easy way out of this. I do know that if you were to set your PC to hibernate (instead of power off), that it would work fine (and FASTER). The only way RR will be able to resume after a power off is if you use the Power Off, Restart or Exit of RR to perform such function (or before doing so).
  3. #73
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Deepgear
    Guino, you're the man !!
    I got nearly everything working with no menues. So the importatnt commands are controlled by the RR Skin.
    Many options are simply not needed (I think )
    I only have a Problem with this command here:
    "MM;AddSpeedCamera|-1|-1|0|-1"
    This should add a speed camera on the position you are now, regarding to the readme.
    But I always get an error. Could you maybe help me?
    Thx
    I can look at what could be the problem... never really tried that..
  4. #74
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ccsnet
    Guino... as I said I have tested this manually though the skin switch and it does not have a problem. Also the info for the gamma settings are in the gerneral ini file as shown below... that is unless you have changed the format from MC.
    Terran
    I have already fixed the font issue with the Day/Night skin.. expect next release.
    On your General.ini file, I see ALL values for Night and Day using "-51", if you press Gamma with that skin, you should basically see it changing "down" once and never changing again (until you exit out of the software). That is EXACTLY as I have just tried it with your settings. You should set DIFFERENT values for DAY and for NIGHT if you wish anything to change. As a reminder, the AUTO gamma change is not yet implemented.
  5. #75
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by holistic
    does the same here... but not everytime only once in a while.... but on mine it dosent reset to arial it displays the arial font on top of the original font
    I get the double-font printing as well, but as far as I can tell, it's only on the main screen.
  6. #76
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by guino
    Guino / Drait - OK... Bad example... thats a night ONLY skin... and I was trying to work out if I was missing some thing... relistically I agree with what you both said... and thats how it is normally... I was in a rush.
    Good to hear its fixed though... Will test when its out... In thery this way should alow the skin to be swapped and the gamma changed at the same time... ideal.
    Terran
  7. #77
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Terran
    Sure, just make the button code like "GAMMA||DAYNIGHTSKIN" on both skins.. pressign the button will do both at the same time..
  8. #78
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    found something interesting in the last couple days with 2-27... sometimes when i hit the "next" or "prev" buttons, or actually any button, it doesnt respond for a minute or 2 and then it does all the button presses all at once. It buffered all my presses, and didnt execute them when they were suppose to. Instead it did them all at once and next thing i know it im fast forwarding thru my playlist like a bbbbbbbunch of times and it also happens with the girder remote. hmmmm anyone else have this happen?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  9. #79
    Jan 2005
    In the music player if you skip a song using the buttons the display moves the list of songs down
    However if you just let it play through to the next song the list does not move when the next song starts, is this intentional?
    Pilt
  10. #80
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Pilt
    Pilt
    This is an option, go into RRConfig and check "List Follows Song" and it will follow the song when it changes.
  1. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 01:27 AM
