I have never tried for a lack of skin.. I do believe I made everything separate enough to where you should be able to do it.. although this probably would make the screen look cluttery, I'd strongly suggest to try (if you want it).. then if you come into any problems, let me know and I'll look at it.. I do know that when having more than one list (playlist + folderlist) you will be able to scroll whichever you list using the same up/down/pgup/pgdown and even touchwheel -- but there's a trick: only the list last used will be scrolled, so to scroll a folder list, you click on it, then scroll however you want, then to scroll the playlist, you should click on it, then scroll, however you want.Originally Posted by xequtor
LinkBack URL
About LinkBacks
