When using Tags this is what RR does: Loads the ID3v1/2 according to your options, then grabs all info available, then loads the next ID3v2/1 and pulls off any "missing" info of the first tag from it. That's how it makes up the tag info. Now, if no tag V1 or V2 is found, then it defaults to the file name formatting. If you are getting spaces is because you simply have bad tags. There's no way for me to know if the tag format you chose (custom format) is empty or if it has the correct info. This is only because people add stuff like / or , or () into the format of the ID3 info.Originally Posted by RoyN
This is a very sensitive part of the code, that is, any slight changes here/there can make the loading of songs fairly slow, so I can not start adding a bunch of code to load tags then check every bit of info and if it's not everything perfect I get from the file name.. I can definitely try to think of a solution for the empty spaces, but I can't garantee I'll do it because it might just slow everything down.
Not sure I understand this... what you mean the number of the song in the playlist ? did you mean the number of songS ? If so, even I have no clue of how to directly obtain that.. the only way of doing it is loading the winamp.m3u file that winamp keeps control. Also, the last song used in the playlist can be viewed in the 2nd line of the resume.ini file if you wanted that for some reason.Originally Posted by RoyN
I have thought of both adding support to "browse" m3u files in RR and also about saving playlists.. I will most definitely implement the browse m3u files soon... the Save playlist feature will come in when I implement an OSK.Originally Posted by RoyN
I hope you understand this project is only 2 months old! So it can't possibly have everything in it already... things are getting done, but there's the right time to do everything..![]()
LinkBack URL
About LinkBacks
buttons for bass/treble up/down would be sweet!
