Results 1 to 10 of 14
Thread: Girder control
    Newbie mick-uk's Avatar
    Dec 2004
    Girder control
    hello,
    just wondering if its possible to control rr, using the tab key? so it cycles through the buttons.
    I have a touchscreen, and visibility is very poor in a bright day, so i am going to remove the touchscreen, and would like to be able to control rr using girder with the minimal number of buttons. up down left right select.
    thanks
    mik.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mick-uk
    hello,
    thanks
    mik.
    unless you have enough keys for all different functions that will be kind of hard.. on the remote control you can set numbers from 1-6 go go to each screen (audio, video, etc).. then you'd need keys for Up/down/pgup/pgdown, Browser, Exit folder, browse folder, play pause etc. right now there's no built in keyboard support to simply go selecting button to button (tab style like windows) ... This will be added at some point.. there are just more important things to add right now..
    Ride Runner RR's Myspace
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Hey guino, I'm in the same boat as I don't have a touchscreen.
    Does RR support scrolling through the various options on the menu screen with the directional arrows on my remote?
    Since the items on the menu light up when you mouse over them, I assumed that you could do this, but I don't have my carpc installed yet, so I can't test it on my remtoe yet.
    I would really appreciate if this could be supported because I have a stock screen in my car and I can't do a touchscreen!
    THANKS a ton!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The support for remote control is fairly simple, each key performs an assigned command. The command does not even need to be in the skin files (believe it or not). But the limitation is one (or more commands) per a single remote button. What I did for instance was assign keys 1-6 to go to Audio, Video, DVD, Radio, Apps and GPS respectively. You can then call any of those screen from anywhere with the push of ONE button. then I assigned arrow keys for Up/Down, Browse/Go Back and assigned the normal playback control keys: Play/Stop/Next/Prev... this works a lot better than having to press the same button many times to get to the option you want, but it also requires more keys available. I still intend to add basic keyboard support at some point.
    Feb 2005
    The Yay Area (SF)
    sweet thanks! the 8 way directional arrows on the ati 2 match the look of the buttons on the bottom left of the music screen perfectly.
    That makes sense. Should work fine since i have two dpads, I can program the other depad with the arrow keys when you get them implamented and use the number keys liek u said for now (well when i get my carpc running)
    THANKS
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by contaygious
    THANKS
    Any use ?
    Terran
    Attached Files Attached Files
    Feb 2005
    The Yay Area (SF)
    Thanks! is it different than RRX10.GML?
    Jan 2003
    Its set up for a MediaRemote..... which are also X10...
    Terran
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    How is possible to link the GML file into RR?
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Jan 2004
    Jersey/NY
    girder I believe.
  1. Replies: 7
    Last Post: 03-11-2005, 12:36 PM
  2. XM Radio_Girder control and XM
    By jcdillin in forum FP Bug Reports
    Last Post: 01-01-2005, 11:42 PM
  3. Remote control for medicar with girder
    By LanoX in forum Newbie
    Last Post: 10-26-2004, 10:27 PM
  4. Girder exported control files
    By ddt in forum Software & Software Development
    Last Post: 11-30-2002, 05:20 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
