Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: How to get VIS to show...
  1. #11
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Quote Originally Posted by guino
    Go in RRConfig and make sure that you've selected the VIS you want and make sure you select it in WINAMP too.
    I have done this, but the VIS never appears on the screen. I always have to click on it in the taskbar before it appears on the screen.
  2. #12
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i dont know if you guys have seen this but sometimes i have to hit the Vis button like 4-5 times for the window to finally pop up in my audio playlist screen. Also, if anyone is running a M10K VIA... experienced any major lag issues? my vis starts pretty smooth but after a minute or so, it totally starts to lag... maybe a setting in winamp i need to change? thanks guys
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  3. #13
    Mar 2005
    Quote Originally Posted by Chita79
    I also have an Epia M10000 and it runs well. Maybe you have to change the number of frames/second to a lower number. I use 20fps and is runs perfect.
    Do you also have the 'choppy' DVD problem?
  4. #14
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    That's why I got rid of my Epia a long time ago...
  5. #15
    Oct 2004
    San Diego, CA
    @Erwin
    ill change the fps settings, hopefully that does the trick....
    Yeah, i get choppy dvd & video playback once in a while... sux
  6. #16
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Erwin
    I have AVS running on my desktop and milkdrop on my carpc.. this works for sure.. tell me (please number your answers):
    1.Which vis you're using ?
    2.How you're selecting the vis in winamp ?
    3.What's your RR.INI setting for "visname=" ?
    4.Which Winamp Version you use ?
    5.Do you have wiamp set with the CLASSIC skin ?
    Then I can better determine what's wrong.
    Ride Runner RR's Myspace
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @Erwin
    I can't make your CPU speed faster.. the only thing I can recommend is to use AVS with the Pixel Doubling option OR another vis that doesn't use as much CPU. I don't know how I could check on the Choppy DVD stuff, the slowest machine I have is a Athlon 1.2Gh with an ATI ALL in Wonder in it (that has hardware acceleration).. the reson for this is (as I said before), MPC probably isn't set OR doesn't support the hardware acceleration you have (if any).
  8. #18
    Oct 2004
    San Diego, CA
    yeah... im not expecting much with my VIA cpu, there is a trade off for low power/lower heat cpu's!
  9. #19
    Mar 2005
    5.Do you have winamp set with the CLASSIC skin ?
    1) I use the Milkdrop vis
    2) choosed it in the option menu of RR
    3) visuname =!Winamp Gen! AVS (I don't know what this means)
    4) V5.05
    5) I use the default Winamp modern skin
  10. #20
    Mar 2005
    @Erwin
    My DVD's alway's play choppy, the only way to solve it is to use an external DVD player, I use PowerDVD. The only problem is that I can't use an external DVD player when I use the 'inorkuo' skin.
  1. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 08:14 PM
  2. Replies: 2
    Last Post: 09-28-2004, 07:43 AM
  3. NDRA Drag & NOPI Show - St Louis, MO 7/24-7/25
    By NOPIMAN in forum MP3Car Gatherings
    Last Post: 06-16-2004, 11:46 PM
  4. NDRA Drag & NOPI Show - Bristol, TN 7/10-7/11
    Last Post: 06-16-2004, 11:44 PM
  5. NDRA Drag & NOPI Show - Mechanicsville, MD 6/26-6/27
    Last Post: 06-16-2004, 11:41 PM
