Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: How to get VIS to show...
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Would someone let me know how I set up to see the VIS? With the default install, when I push the eyeball, the vis window opens up behind RR. What settings do I use? The rrconfig is default set to the MilDrop plugin. The closest I could get is using the following but it isn't quite right. (top pic)
    When I double click to close it just puts it in a window and then Winamp is on top of RR. (bottom pic)
    I am using the late 2/27 release with Winamp5.08.
    Lpx
    Lpx is offline
    Dec 2004
    RR 2-15-05 out! Gadgets supports..
    -I DO recommend the MilkDrop plugin -- disable the "Integrate with winamp option" for enbbeding. Also, you can go full screen by double-clicking the visualization window.
    Apr 2003
    HOT Arizona
    Sweet, I'll give it a try.
    You joined mp3car.com just to help me....aw shucks.
    Apr 2003
    HOT Arizona
    Thanks for the help! Works like a charm.
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    yeah I had to do that too.
    Gotta luv this forum
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    saved me some time thanks
    Ride Runner RR's Myspace
    Variable Bitrate Erwin's Avatar
    Mar 2005
    I tried the setting too, but when I return from fullscreen mode The vis dissapears after RR. How can I solve this problem?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    When you return from full scren, MilkDrop is DISABLED, you just have to hit the vis button once to reopen it.
    Mar 2005
    Thank you!!
    The vis also doesn't stay on top when I click a button. How doe I change that?
    Can I also change the surrounding frame of the vis?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Go in RRConfig and make sure that you've selected the VIS you want and make sure you select it in WINAMP too.
  1. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 09:14 PM
  2. Replies: 2
    Last Post: 09-28-2004, 08:43 AM
  3. NDRA Drag & NOPI Show - St Louis, MO 7/24-7/25
    By NOPIMAN in forum MP3Car Gatherings
    Last Post: 06-17-2004, 12:46 AM
  4. NDRA Drag & NOPI Show - Bristol, TN 7/10-7/11
    Last Post: 06-17-2004, 12:44 AM
  5. NDRA Drag & NOPI Show - Mechanicsville, MD 6/26-6/27
    Last Post: 06-17-2004, 12:41 AM
