The only thing changed was the RR.exe file in the BINARY package -- should have a newer mod date. I do not control the installshield, it will be updated when it gets to be updated.Originally Posted by ddogg_777
Hmm, mine remembers the track time for both video and audio when I switch between them. Are you using external player (mpc) or built in player?Originally Posted by holistic
Ride Runner RR's Myspace
I'll check this out..Originally Posted by Mr.Fabio
I know what this is, I'll fix it.. sorry.Originally Posted by vortex
Very good question asked.. @holistic: which one ? I'll try it out to see..Originally Posted by ddogg_777
I think I was too fast to download it, it was the correct binary this morning though, the mod date on the rr.exe was 3/02. Last night it was still 2/28 even though the link said 3/02...No worries, I knew it would update eventually. I just wanted to let everyone know in case they got confused.Originally Posted by guino
Hi Guino,
I have carried out the update ones 02_03_05.
I have a small problem with the video player, when I press the button stop the firm video not, for being able to stop it I must hold the button stop pressed in order at least 2 second ones. Same thing for the button play.
You have one solution?
using mpc 8.2 thingy.... it's when i switch in my new skin.... it's alright as long as i use my 3 other skins... dunno know why ??![]()
Hi Guino
You seems to have a solution to everything. I got a problem. When i start my GPS prog in RR it set the sond to left channel, it's the wave that changes.
There is another tread about this but no answer what I can see.
GPS software for my carputer (Europe/Norway)
Any idea?
By the way it's Via Michelin Map Sonic
Never seen that happening.. are you using MPC or built-in video player ?Originally Posted by manung
Please add this to your RR.INI file:
debugmode=true
then run RR, go to the video player and do what you need in order to stop and then play the movie..
PM me with the log file please.
