Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 78
Thread: RR 03-02-05... Fixes only..
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by holistic
    using mpc 8.2 thingy.... it's when i switch in my new skin.... it's alright as long as i use my 3 other skins... dunno know why ??
    This should only happen when going into the video_browser or Mixer screens. Going into any other screen from the video player should return RR into audio mode. I'll try it though..
    Ride Runner RR's Myspace
  2. #22
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Clarre
    Hi Guino
    You seems to have a solution to everything. I got a problem. When i start my GPS prog in RR it set the sond to left channel, it's the wave that changes.
    There is another tread about this but no answer what I can see.
    GPS software for my carputer (Europe/Norway)
    Any idea?
    By the way it's Via Michelin Map Sonic
    That is mostly weird, there's no code in RR whatsoever to change the balance of the wave line (only master). That is not to say that the code that allows RR to execute an application has nothing to do with the mixer. Have you tried a different skin ? If that makes no difference, I can only assume that something in your mapping software is actually messing with the mixer. Maybe it's got like MONO voice prompts and it is preparing itself in case it needs to play them or something.. I'm pretty sure that's not a bug in RR..
  3. #23
    FLAC mauri's Avatar
    Jan 2004
    Hi Guino,
    i have installed the new binary 03/02 (sure, install ok ) but one problem:
    All number displayed (es. volume xx% or temp. etc...) is displayed not good,
    the figures have overlapped and impossible to distinguish her.
    This happens ONLY in my CarPc, not in my Home PC.
    Exsample this:
    Wath is it???
    In the old version this thing didn't happen...
    You question in the site: Fixed (?) Dual font problem?
    Second me no
    Mauri
  4. #24
    Nov 2004
    I have updated the Installation now, sorry guys I was busy today and Just saw that guino had updated the source today.
    I have now updated the Installation program.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Hi Guino,
    Exsample this:
    Wath is it???
    Second me no
    Mauri
    Are you sure you've got 3-2 ? 2-27 is the one that was doing that.. please check the rr.exe file's modified date/time.
  6. #26
    Feb 2005
    It's not a bug in RR, it's a well known bug of MapSonic. The balance can be easily corrected moving up and down the wave mixer slider (it returns to center doing this). If this could be handled at MapSonic startup, the problem is solved.
  7. #27
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Opps.....i have checked:i have the 28/02 RR.exe install in my carPC...
    Sorry
    tomorrow test it...
    Mauri
  8. #28
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by AngelGR
    if you tell me the name of the mapsonic EXE file you use to run it, I can add something for that in RR.
  9. #29
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    hey guino, did you check out that button pressing problem where it doesnt respond to buttons for a little while and then buffers all the key presses and does it all in one shot like a minute later? thanks again...
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Chita79
    That makes perfect sense.. the question is what exactly that you're pressing that is making that happen ???? RR buffers all input for later processing IF you're trying to press something while it is still processing your last command. So if you were to press video, then NOT wait for it to finishing load/resume the video and start pressing a bunch of stuff, it is very likely that what you're saying is going to happen.
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 01:27 PM
  3. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 02:27 AM
