Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 78
Thread: RR 03-02-05... Fixes only..
  1. #31
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    hey Guino!
    Anyway rr can display the song title from the filename if it doesn't find anything in the tag? I have some albums where the file name is the song title and the artist is in the tag and the winamp playlist shows them correctly, but rr just shows ARTIST ? BLANK
    THANKS!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  2. #32
    Oct 2004
    Quote Originally Posted by guino
    Never seen that happening.. are you using MPC or built-in video player ?
    Please add this to your RR.INI file:
    debugmode=true
    then run RR, go to the video player and do what you need in order to stop and then play the movie..
    PM me with the log file please.
    Hi Guino,
    I have inserted the line debugmode=true in RR.ini but it does not change null, same problem.
    Exists one solution?
    Attached Files Attached Files
    • File Type: zip RR.zip (787 Bytes, 47 views)
  3. #33
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by manung
    Hi Guino,
    where is your debug log file ??? after you add the debug mode line, you should run RR and reproduce the problem so I can view the log and maybe tell what's wrong from that...
    Ride Runner RR's Myspace
  4. #34
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by contaygious
    hey Guino!
    THANKS!
    That's because you have bad tags.. to display the title from the file name you should remove the tag. I may try to improve a little on this, but this is a delicate part of the code that if anything goes wrong, everything gets slow.
  5. #35
    Feb 2005
    The Yay Area (SF)
    no worries. I have all my stuff tagged it's just that it's easier to tag artst and genre for a ton of songs then it is to go through song by song and type the title. If it's possible later it would be cool if the tag is blank for the song title to take it from the file name like winamp does. Otherwise, it's cool because most of my stuff has a song title in the tag.
  6. #36
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Guino, here's a bug with the default skin in the 3/02 release. I'm not sure who needs to see this but here it is...
    shuffle and repeat overlap the temperature.
  7. #37
    Feb 2005
    if you tell me the name of the mapsonic EXE file you use to run it, I can add something for that in RR.
    Thanks very much, guino. The executable file for PC is called "mapstore.exe".
  8. #38
    Low Bitrate fishy's Avatar
    sydney
    hi all,
    the link on Bryans website is not working for the update install
    Hilux Surf (4runner) install
    false floor in rear housing;
    4 channel amp
    600w cont. inverter.
    Also- DigitalWW 7VGA indash
    headunit for FM/AM,DVD,SVCD,CD,MP3
    P4 3.0 with low profile AGP card.
    4x4" speakers (splits) in factory locations
    BU-303 GPS
  9. #39
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by ddogg_777
    there is another little bug. when the song changes, the title in the central grid is not highlighted automatically... Tryed with all skins
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  10. #40
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    It's not a bug...
    You have the indicators with same Y position of the temperature labels...
    Edit audio_player.skin with notepad and decrease Y value to the indicator
    that have about this structure:
    I0A,XXX,YYY,xxx,yyy,"SHUFFLE"
    I0B,XXX,YYY,xxx,yyy,"REPEAT"
    See my car and donate for spinning logos at www.ildena.it/carpc
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 12:27 PM
  3. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 01:27 AM
