Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 78
Thread: RR 03-02-05... Fixes only..
  1. #61
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by kevlar
    guino, thanks for the thorough feedback regarding the TV/Radio combos. Does the DLink you have play both TV and FM alright, or do you have that mix issue?
    Which tv/fm usb combos do you know that don't have that issue?
    The DLink is FM only.. Any Radiator supported TV/FM card or device should not have that mixing sound problem..
    Ride Runner RR's Myspace
  2. #62
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Guino... is it possible for those that are using the inbuilt Gamma that you can have an addtion in the gerneral ini file of a skin to change if set to say 1.. MapMonkey or Freedrive to night mode... I know its been done by Gamma control but for those of us using a night skin say it does not use GC at all.
    Please ????
    Terran
    PS This way you can change the skin, set a diffrent gamma setting and tell MM what to do... any body else intrested ?
    EDIT - Just a thought you could do the exact same for Phonecontrol where you can tell it to change skins.... ( I think )
  3. #63
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ccsnet
    Please ????
    Terran
    Ok, I can probably do that... although if you're already using that Day/Night Skin thingy, you can already do that by simply setting the button code to switch to NIGHT skin to:
    "GAMMA||MM;Set_Color_Mode|0||DAYNIGHTSKIN"
    then on your night skin you'd make the button code to switch to DAY skin to:
    "GAMMA||MM;Set_Color_Mode|1||DAYNIGHTSKIN"
    Of course the above only works if already have MM running.
    I will try to accomodate most of this tweaks at some point, but there's still a lot of important stuff to be worked out first ...
  4. #64
    Jan 2003
    Quote Originally Posted by guino
    Cool, I'll keep this safe and remind you once in a while...
    T
  5. #65
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I am trying to use the SDK but I am having some problems... i.e. I want Vol-... But it will decrease volume each time I click/mousedown the button in my app.. I've set a loop to stop when mouseup, but if it reaches 0% before I release the mouse my app and RR freeze!! I am not too keen on VB6, so any help would be really appreciated!!
  6. #66
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DjBac
    Well, have you tried to to simply type VOL- in the SDK example and hit the button a bunch of times (even after it reaches 0%) ? If that doesn't crash, than it's something you're doing.. otherwise let me know and I'll take a look at it.
    I'm just really interested in how you make a loop stop with mouse up.. that event will just will never happen if you are in a closed loop.
  7. #67
    Jun 2004
    GREECE/Athens
    Code:
    Dim VolDown As Boolean
    Private Sub VolD_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
    VolDown = True
    Do
    COMSend "RoadRunner", "Vol-"
    Loop Until VolDown = False
    End Sub
    Private Sub VolD_MouseUp(Button As Integer, Shift As Integer, X As Single, Y As Single)
    VolDown = False
    End Sub
    As I told you I am not too keen with VB6!!!
    Any way to implement VOL with my app??
  8. #68
    Oct 2004
    Now are you using MPC or the built-in video player ? I'd suggest trying the other one to see (just run RRConfig and check/uncheck the built-in player option in the video section).
    Let me know...
    ok guino excuse for the delay,
    I have selection option "USE BUILT IN PALYER" in the section video player of rr config and hour seems not to have no problem.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Code:
    VolDown = True
    Do
    End Sub
    VolDown = False
    End Sub
    Dude, that above can freeze ANY computer and application.
    Erase all the above.. then add a timer control, set it's interval to like 100, make it disabled, then on your mouse down you enable it, and on mouse up you re-disable it, it will work guaranteed.
  10. #70
    Jan 2003
    Just a thought... what about tiying mute to the pause command ? If your muting the app your more than likly going to want to listen to the music from the point you muted... just an observation.
    Terran
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 12:27 PM
  3. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 01:27 AM
