Page 8 of 8 FirstFirst 12345678
Results 71 to 78 of 78
Thread: RR 03-02-05... Fixes only..
  1. #71
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by guino
    Dude, that above can freeze ANY computer and application.
    Erase all the above.. then add a timer control, set it's interval to like 100, make it disabled, then on your mouse down you enable it, and on mouse up you re-disable it, it will work guaranteed.
    Thanx a lot!!! Haven't thought of that!!!:P:P
  2. #72
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Quote Originally Posted by ccsnet
    Just a thought... what about tiying mute to the pause command ? If your muting the app your more than likly going to want to listen to the music from the point you muted... just an observation.
    Terran
    That's a good idea, that should be done with all skins I think.
    Hey, guino is there anything I could do to make the album cover choose the "folder.jpg" before other images. I have all my album covers called that, but sometimes there are other images in the folders like the back of the album cover etc.
    I use album art downloader and that's what it names them...
    Also, the shuffle and repeate logos still cover up the temps for me.
    THANKS!
    U da ma!
    Tay
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  3. #73
    Feb 2004
    Hi Guino,
    one of my german-community member asked me for a config in RR, simply showing the whole filename, not the Id Tags. I tried to select "Do not use Id" but ot only showes the song name.
    Is this possible?
    Thx
    Deepgear
  4. #74
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Terran
    just change your skin code to "MUTE||PLAY", as long as you don't manually pause then hit the mute button, you should be ok. If that happens, you can simply use the volume buttons/slider to unmute without changing playback. But then again, if there's enough requests for this I can make a more complex based command for it... I honestly never use the mute button, I always use Pause (which stops the sound anyway).
    Ride Runner RR's Myspace
  5. #75
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Deepgear
    Hi Guino,
    Is this possible?
    Thx
    Deepgear
    Set RRConfig for no Don't Use ID3 tags, then set the option for "no formatting" and set the "titlesafter" option to something like "*****" (no filenames have * so it won't filter the titles). Then if you want to show the extensions set "show: ... extensions"
  6. #76
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by contaygious
    THANKS!
    U da ma!
    Tay
    1-REedownload the Brush metal skin update -- it's updated.
    2-just go in RRConfig and set the Video Album Art field to "Folder.jpg" instead of "*.jpg" (no quotes in anything).
  7. #77
    Feb 2005
    The Yay Area (SF)
    sweet looks good
  8. #78
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Its funny you should say that because 30 mins later I thought why not use the pause command on the frount menu skin rather than mute...
    Terran
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. RR 2-27-05... LATE Release (Fixes)..
    By guino in forum Road Runner
    Last Post: 03-02-2005, 12:27 PM
  3. RR 2-20-05 ... Bug Fixes ...
    Last Post: 03-01-2005, 01:27 AM
