Results 1 to 10 of 14
Thread: Recommended radio / tv usb ?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    any idea whats a good combo usb thingy thats compatable with RR ? Thinking its time to start playing again
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Any WDM compatible Camera/TV tuner should work (most newer devices). For Radio, I'm adding support for D-Link and Radiator, so any radio card that works with radiator should work.
    EDIT: I have an ATI All in wonder plugged into Line in and the DLink plugged into the Mic.. both work great..
    Ride Runner RR's Myspace
    Mar 2004
    California
    Guino, which ATI All-In-Wonder are you using for FM with Radiator? Is it a 9600 or above? If so, I'm in luck!
    Kevin
    Audi A4 Carputer, 80% setup.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The ATI is only for TV.. There are no ATI's with radio that I am aware of....I like the ATI for the reason that when you turn it off in the PC, it cuts out the Audio output -- which would allow for using it in THE SAME audio input with a Radio device that does the same (i.e DLink Radio). You can most definitely use any other Radiator supported card -- Now, if it will work using the same audio input, that depends on your FM Tuner.
    Mar 2004
    California
    Well, according to the ATI page, my manual, and looking at the device, it has FM
    ATI All-In-Wonder 9600 Pro and XT
    Kevin
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, if that's the case, if it supports the FM WDM interface you may want to try it in Radiator with this External DLL driver: 8x8wdmfm.dll (It's made for other cards, but it basically just controls radio using the WDM interface (no port access).
    Mar 2004
    California
    I'll test it out.
    Kevin
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by CdRsKuLL
    CdR
    I just bought the Hauppaug WinTV-GO-FM which is a TV/FM receiver combination. It is PCI not USB, but in my configuration I should be OK... It uses the 878 chipset which Radiator seems to unilaterally support. I'll be trying it tonight or tomorrow, so I'll post successes... I have been asking about this for the last week, but it seems your thread is getting noticed better than mine did.
    Heres hoping
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    I finally got my AverMedia AverTV Cardbus Plus today -- it's a PCMCIA tv/radio card. TV and radio can both be controlled through the Winamp tv plugin. Somehow I am not yet getting any sound when using the plugin, though. Any idea what could be wrong, Guino? It may well be my inexperience with the winamp plugin settings and/or DirectAudio. The card itself performs great with the bundled software and makes a cool gadget for Epia MII owners with a free PCMCIA slot.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mox
    I'd just double check your windows mixer settings -- that is, the audio input line you use.. There's a whole audio tab in the plugin where you should be able to set this up.. You should probably just try this stuff on winamp and make suer it works there before trying it in RR. I'd also set the TV input line (in RRConfig) to Disable while testing.. then if it works you can re-enable it (if needed).
  1. USB TV tuner
    By egeekial in forum General Hardware Discussion
    Last Post: 08-24-2004, 01:49 AM
  2. Laptops, and USB radio, and other goodies
    By wkolodny in forum Classified Archive
    Last Post: 08-21-2004, 09:13 AM
  3. Anyone found a new set of drivers for the D Link USB FM Radio ?
    By SAScooby in forum General Hardware Discussion
    Last Post: 08-20-2004, 02:21 AM
  4. What to do about usb FM radio D-Link discontinued...
    By erains in forum General Hardware Discussion
    Last Post: 01-07-2004, 08:11 AM
  5. WTB: D-Link USB FM radio
    By Stine161 in forum Classified Archive
    Last Post: 11-12-2002, 07:02 AM
