Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: On-line for download my hardware for RR (Serial Voltmeter) implemented by Guino
    FLAC mauri's Avatar
    Jan 2004
    Ok guys,
    I have put in download my serial voltmeter, full packet.
    Read the README file.
    Its work perfect with RR , tested in my carPC.
    See the original post
    My small hardware to RR
    Link for download :
    http://xoomer.virgilio.it/tecno-maur..._Voltmeter.zip
    To view the schematic see the attachment
    Good work
    Mauri
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    So, if I understand this correctly, when the computer is off this device will power the GPS through the 5V of the floppy connector (which is probably linked to the 5V usb). Is that right? If not, is the device connected to the GPS some other way?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This seems nice allright, the link says "Forbidden" though.
    I would like to have the Battery Voltimiter, just don't know if I'm up to gathering all the electronics to put it together. About the GPS, I don't think I'd mess with it because my GPS aquires a lock typically in 5-10 seconds (regardless of how long it's been off).
    Ride Runner RR's Myspace
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    yea i dont undestand why you need the gps in the equation?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    guino's Avatar
    Nov 2004
    Toronto, Canada
    His circuit CAN (doesn't mean it has to) power the GPS every hour or so for 3 minutes so as to not loose the "lock" of current location and be "warm" or "ready" when you actually get to turn on and use your carputer.
    oh so this isint a real volt meter? like monitor my cars voltage in RR when im driving?
    1990 Jeep Cherokee
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it is that too! haha it's TWO projects in ONE circuit. One part is to measure your battery's volts the other part is to keep the GPS "warm".
    err, is their a simple voltage meter easy to build that will work with rr? since i have no idea how to read that above...
    1990 Jeep Cherokee
    guino's Avatar
    Nov 2004
    Toronto, Canada
    well.. I've only built support for this one, BUT he's supposed to have a parts list, board building instructions etc with the link above... If you find something cheap/simple to assemble let me know and I can definetely work on a support for it.
    Apr 2003
    HOT Arizona
    Quote Originally Posted by WebDog
    Here is a picture of the above schematic, it's a lot easier on the eyes...This doesn't look nearly as bad now does it?
