It works good at all...
Crash problem of DLink was known... it sucks... but don't worry.
Great job Guino![]()
I've had my Dlink blue screen and crash my desktop before now, not the end of the world really, was only a couple of quid, hope the MP3Car radio being designed ends up being worthwhile and stable.
See my car and donate for spinning logos at www.ildena.it/carpc
Ok, I believe I have found this USBRADIO.SYS that does not crash.. it really does not seem to crash, even after hibernation... BUT here's the down side: It strips you out of ANY Seek/Search Function.
It is possible to make extra support to have BOTH the original and the new version of the file in the system -- and then use the OLD one for Searching Presets and then when done, restore the NEW one for normal (non-crash use).
But this will still prevent you from using the "seek" functions (you'd have to tune everything by using the presets or manually fine tuning and listening. Also the Stero Indicator does not work under the new driver.
Ride Runner RR's Myspace
well I think that if its a choice between blue screen or no blue screen, then dont worry about the seek function. I think most people will agree
I'd rather have stability and loose the seek, I know most of the stations locally I listen to so wouldn't miss the seek feature.
i'm sorry, once again, thanks guino for your work, but, am i missing something? my TV/FM card (cinergy 600) works flawlessly with radiator, but there's no way to hear anything when i launch radio with RR menu... what's wrong? by the way, instead of frequency i see "FM 0.00 mhz " ....
Is radiator running ??? sounds like NOT. Go into radio and run task manager to see. if NOT, then you probably did not set up correct settings for the radio in RRConfig.Originally Posted by cyberlancer
Also, PLEASE double check that radiator is setup correctly. and working before running RR.
Ok, I'll like like 5 lines of code and be done with itOriginally Posted by CdRsKuLL
Of course I can't promise the OLD driver won't crash when you're actually using it to Search Stations... but it gives a lot better odds...
yes, radiator's running (see 107.90 FM - radiator.exe in TaskManager and the process also is active). Radiator works fine when used standalone and i think i configured properly RRconfig: radiator checked, path correct, and line-in mute on exit.... i can't figure out what's wrong...
Radiator should be in the TASKBAR (not only in the taskmanager) and it should NOT be running prior to running RR. Also PLEASE tell me you have DISABLED that scroll title option in Radiator as I stated.Originally Posted by cyberlancer
