Results 21 to 30 of 31
Thread: RR 03-07-05.. Few Improvements..
  1. #21
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    Question
    I have the
    00630238: SWApplicationWindow "ViaMichelin MapStore 2.3"
    But where shall I put in the name? In the
    Map Monkey Path
    GPS Path
    or
    GPS Window Name?
    and shall I use GPS Mode External?
    Excuse me but this is little more then I can handle, but I do the best to learn.
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
  2. #22
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    If it is the same version, try:
    External GPS Mode, Window name "ViaMichelin" (without the "") or "!SWApplicationWindow" (also without the "")
  3. #23
    Feb 2005
    That's a good start, I need some other Window names as to find something that is always in there...
    Sorry Guino, I don't know if you've seen this (our posts have the same time):
    http://www.planetsourcecode.com/vb/s...38589&lngWId=1
    It can be a good "generic fix", keeping locked the wave balance always.
  4. #24
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Nothing you try on the current version will work... because the window name in RR right now is just not correct (in RR) according to the info you gave me.. The info you gave me is more than good, I just would like to see the window names from other people (if possible) as to accomodate everything at once.
    EDIT: The mixer in RR is more than enough and this is only ONE line of code.. kjust gotta get the correct info and that's it..
    Ride Runner RR's Myspace
  5. #25
    Feb 2005
    Nope not even that works. And there seems to be another problem it raises the volume to 100%, but of course only in the left channel. So I have to go the hard way and autohide the taskbar so I can adjust it manually.
    Oh BTW thank you for your support! It's great to have this forum so
    thank you all. I'll try further.
    Via Epia M1000
    512MB RAM
    Netgear MA111
  6. #26
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Clarre
    If you want to try a quick fix, place this file over your current RR.exe (must close RR first):
    http://rmc.pimpedwheels.com/rr.exe
  7. #27
    Mar 2004
    Stockholm, Sweden
    I have the
    Map Monkey Path
    GPS Path
    or
    GPS Window Name?
    You don't have to care about Map Monkey Path, put the path to MapStore.exe in the GPS Path, put "ViaMichelin" in the GPS Window Name, and select GPS mode to External. This should get the application to run embedded, this is working for me, but Guino has to change RR to fix the balance problem...
    Guino, I just tried to change the line to:
    "If LCase(.AppName) = "viamichelin" Then AdjustOutput IdxWave"
    and it is working perfectly...
  8. #28
    Feb 2005
    Sorry Guino but it's the same.
    and you should know how greatful I'm for your help.
    I'm sure ther will be a solution.
    Via Epia M1000
    512MB RAM
    Netgear MA111
  9. #29
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well since Passe had how to test it and says it's working, then I've updated that exe for you Clarre, with Passe's fix
  10. #30
    Feb 2005
    Smile
    Yeeeha! That's it working great. Thank you, thank you, thank you.
    As I said it would be a solution for it. Now I have to copy over all new stuff to the carputer. I'm sure it should work even in the car. Otherwise I be back.
    One more time your are the best THANK YOU.
    Via Epia M1000
    512MB RAM
    Netgear MA111
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
