Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: RR 03-07-05.. Few Improvements..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 03-07-05.. Few Improvements..
    A few improvements from the radio version:
    -Added radio "LOCAL" skin command
    -Added "SAVELIST" skin command
    -Added "MINUS1" skin command
    -Added Dlink Automatic Driver Switch (Crash prevention)
    -Added special handlings for skins with a Folder List and a Playlist on a same screen
    -Added Map Sonic GPS wave Line Fix
    I have included the DLink drivers (OLD&NEW) on the binary and source packages. RR will automatically switch them accordingly when you search presets. This is something that can only be done in 2000/XP machines, but I believe 9X/ME machines do not have the problem with the old driver.
    PLEASE NOTE:
    The NEW DLink driver does not support seeking or the stereo indicator -- but it really doesn't crash on 2000/XP. If you wish to keep using your old driver, simply delete or rename the DLink sub-folder in RR. If you're running on 2000/XP, RR will still try to reset the DLink card as before using it to prevent crashes (as often). If you don't wish RR to reset your DLink card and wants to speed up the radio loading, you can simply delete/rename the devcon.exe file in RR's folder.
    Man I need to start making some FAQs...
    Let me know,
    Guino.
    Ride Runner RR's Myspace
    Sep 2003
    LA, CA
    guino
    so you found new driver somewhere?
    sorry for late...
    i had driver on my carpc...
    i just got it downloaded today...
    well i think you've got it...
    it is same size as one i've got...
    Nov 2004
    St Louis
    O. K. I like it so far, but there's one more improvement I'd like to see. Can you implement the ability for me to listen to videos on any page. Right now as soon as I switch away from the video the radio or MP3 player comes back on. Sometimes I'd like to listen to the videos even when I navigate using GPS. And if I had video controls and info available while doing so (like you did for the radio), that would be all the better.
    DVD playback, too.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Particularly usefule when listening to music videos, and checking gps stuff...
    EDIT: maybe putting an extra button ont the video screen, like in GPS (X - to quit video, and <- to keep it running and goto menu)
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    Now that radio is done I have a few requests.
    * Can we save audio playlist as m3u file
    * Remove 1 from playlist
    is it possible to intergrate winamp library? as it already easily allows you to create/ view edit playlist and search all my mp3s in like 2 secounds.
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Remove 1 is already on Guino's "duly noted" list (per the Requests.txt file)
    Nov 2004
    Updated the Installation for 3-7-05.
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @vortex and @Drait
    The Changes above mentioned ARE for what you want.. you CAN already do those things, you just need a skin that supports it. RR will save playlists you make in your music folder unless you set a "playlistpath=<PATH>" in your RR.INI (still needs to be added to RRConfig).
    Dec 2004
    NorCal
    SAVELIST and MINUS1... you da man Guino!
    BTW, you've got PM.
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    Question
    Thank you Guino for all that work you do with RR.
    One stupid questin how do I use the Map Sonic GPS wave Line Fix?
    I try to use the new updates but it seems to be the same problem as before for me. I must be stupid os something. I'm sure I've checked everything, but
    I must have missed something.
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
