Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: auto volume control
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    auto volume control
    Just wondering..
    The faster you drive, the louder the noise becomes in your car, so you have to set the volume higher to hear the same.
    I'm talking if you have set your volume to conversation level, and not at competion level or so.
    Could it not be possible to make some kind of program that auto adjusts the volume to the driving speed? Maybe using GPS or so?
    Searched for this in the forum but couldn't find anything? Has this been done before?
    If not, would it be hard to make?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Phythorian
    Just wondering..
    Many cars (GM) have that built in their stock players.. it is definitely possible to do that using the GPS speed, although, not sure how to calibrate it as it stands RR can only pull GPS speed info from MM (and I haven't seen any other front end doing it either), but could definitely be done..
    Ride Runner RR's Myspace
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Can RR grab nmea 1.83 data ?? or does mm do all of that intrensically ? if RR can grab the data it can just monitor the speed of the vehicle and calibrate the volume that way..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by IntellaWorks
    It COULD, but then again most GPS software (including MM) open (and LOCK) the serial port to where no other application has access to it, so unless somebody can make me a COM Port SPY (like Sysinternal's PortMon), there's hardly any other way of doing this short of getting your GPS app to deliver or allow polling this info from it into RR.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Why not use speed+mic for this? That way we can compensate for windows down and such? The adjustmen should be very drastic and there should be some way of ignoring "conversation", like detecting bakground noise, or hissing from windows?
    EDIT: what about considering noise only after 5secs of CONTINUED sound level? this should compensate for voices vs. wind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Noise, could work, but then if you have a Mic. is probably because you use NaviVoice, and threfore the Microphone line is also Locked for access. Maybe Something to lower the volume by mic. levels could be added to navivoice (since it holds the volume level info -- maybe, that is, if the SpeechAPI allows for reading that)
    Dec 2004
    Netherlands
    That's what I thought off in the first place, but when you play you're music, I think the mic will be picking up the loudness of the music, and raise the volume and so on and on...
    Think the best way is using gps data in a way or so...
    Dec 2004
    Netherlands
    BTW I miss your face Guino, but I like the logo!
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    I think the mic would be a bad idea ... that way your volume would always go up everytime you yelled at someone in traffic
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    São Paulo, Brazil
    As I said above in my suggestion, it would be filtering for CONSTANT noise........................................ read again mate!
    The idea is that this "constant" noise will be able to ignore shouts/conversation/music... Although it might be possible to filter out the music, since the music is generated itself by computer. The idea is that sometimes your window is down, sometimes your window isnt down, sometimes you are accelerating, sometimes there is noise around you, sometimes there isnt... none of this is really 100% tied in to speed...
  1. usb volume control?? help pleaseee
    By 99acuracl in forum Newbie
    Last Post: 02-21-2005, 06:09 PM
  2. Replies: 0
    Last Post: 11-27-2004, 05:47 PM
  3. Volume control question..
    By Kamakazie2 in forum Software & Software Development
    Last Post: 10-07-2004, 06:16 PM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 10:43 AM
