Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: OSK... need help/ideas..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Since OSK for applications is something user's been asking for awhile now, I'm here to first ask for something I need to know in order to work on this:
    The OSK from mediacar is big (entire screen), so that would somewhat suck to type with it onto an application (without seeing what's happening). So there are options:
    1-Make a smaller OSK (with less keys or/and with smaller keys)
    2-Make a "paged" OSK (less buttons and with more than one page)
    3-Make a Touchweel Key Input system that could be "moved" around the screen.
    The two first ones could be easily done quickly... the third one is not all complex, but my idea is the following:
    A squared Window (always on top), with basically a touchwheel using it's entire area. In the Center of that touchwheel there'd be a label that shows which letter/digit to input/send to the application in use. The letter/digit to send would be chosen by rotating the touchwheel. Then there'd be a few arrow buttons (up/down/left/right, pgup/pgdown, then probably a "backspace" and a "exit OSK" button. Clicking the digit label (center) would insert/send that key/letter/digit to the application on focus. This window would be movable by using the mouse/touchscreen and dragging on anywhere of it, and could also include indicators and shift/caps lock buttons (probably would be a bit bigger than a square then..
    To perform the above, I'd also need some sort of "oskwheel.skin" file with the images... This is just a personal suggestion, I wonder if anybody feels this is a good idea or not.
    In any case I'll need some sort of skin made to allow for keyboard and application viewing while typing. Unless everybodys is fine with "blind-typing"
    Let me know what you think,
    Guino.
    Ride Runner RR's Myspace
    Aug 2003
    I like very much the third : the touchwheel. That would also be perfect for Powermate, if there were key Shortcuts assignable for touchwheel rotation
    You may work on a simple OSK, also, for those who don't like the touchwheel, or do not have Touchscreen. this OSK would be half the screen height, with a button to move it from the down half to top half, (and maybe center half).
    And you would choose in RRconfig for OSK type (touchwheel/Classic).
    ...just suggestions, you're the boss
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i dunno how much i like the touchwheel idea since that would be kind of a pain to use in the car while driving! lol (not that we should be searching for songs while driving anyhow) heh
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Well I don't have a touchscreen, so whatever you do, if you could keep that in mind too, people like me would appreciate it!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    Quote Originally Posted by Larsen
    I agree with Larsen. You're going to have people in both camps. I've seen posts here from people who like the single wheel from BMW's I-Drive/Audi's MMI. Others want a typable on-screen keyboard. So if its possible to support both, that would be great and give the choice to the user.
    Feb 2005
    Option 1 + 2 + 3. :-D
    I´ll send you a "concept" later, guino.
    Nov 2004
    France
    I can't insert image but an osk is present in MapMonkey. it covers less than half screen.
    In Mediacruiser OSK can be open in every launched applic
    Osk should be opensource? (ie let transformation querty==>azerty)
    The best : two osk : Querty and Azerty but we can work for you.
    I also like the idea of Audi MMI with a Powermate but in second time.
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I like the MediaCar OSK (full screen). It's hard enough to use an OSK on a 7" monitor, so bigger is better. The only thing I ever use it for is Map Point and it works very well. You just click on a text box it calls up the OSK, you type then hit enter. I'm not sure what apps you guys use in the car that require so much typing, but maybe you could just have the MediaCar OSK wrap the text and/or enlarge the area at the top of the OSK where the text that you have typed is displayed, and maybe make it scrollable. Another idea would be to have the text area go full screen to review what you have written, then back to normal for typing.
    If you are thinking about auto complete for song search, maybe just add a window down the right side to display results.
    Really, if I knew what apps you plan to use with OSK I might be more helpful.
    It's the cake having/eating thing.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I'd say paged full keyboard... The problem with the full keyboard for me is that on 16:9 resolution, like 800x480, I often get the entire screen covered with the OSK, like in MapMonkey I get the osk convering the street names, so I type a bit, then exit osk, the see if I'm in the right place, then open OSK, type more, and so on...
    Could you maximize external apps by hiding the toolbars from RR when using OSK? (Like hiding the Exit/Back buttons and music navigation buttons)
    Feb 2005
    If we could have 3 selectable OSKs...
    First one (Touchwheel):
    Second one (Reduced):
  1. European OSK ?
    By Terpz in forum Map Monkey
    Last Post: 01-24-2005, 11:30 AM
  2. Playlists and OSK ???
    By tolisn in forum FrodoPlayer
    Last Post: 01-23-2005, 05:05 AM
  3. Replies: 7
    Last Post: 05-17-2004, 12:28 AM
  4. Osk
    By mobileh1 in forum MediaCar
    Last Post: 05-08-2004, 07:52 PM
  5. OSK clobbers comm port?
    By wi77iam in forum Software & Software Development
    Last Post: 03-25-2004, 12:12 PM
